Hey all,
I have a problem with my oscilloscope measurement. I'm building an amplifier for a microvolt signal, with about 55dB gain.
While inspecting the output of the three-stage op-amp amplifier, I can see my signal, carried on a 50Hz (or 100Hz) signal - the frequency and harmonic of mains power.
This is a problem, as the EMI signal from the power line is greater than the signal I'm trying to amplify, which causes the signal to be clamped by the op-amps.
Trying to block the signal, I enclosed the breadboard in a metal case, which reduced the interference, but it was still present.
Getting frustrated, I disconnected the probe from my circuit - only to discover that I can still see the 50Hz signal! (I get an amplitude of about 1mV). I can no longer tell whether the noise is coming from the circuit itself, or the measuring equipment. With the probe disconnected from the scope, I finally get a flat-line.
This is a show-stopper - I can't work like this, and I'm getting tired of trying and failing. This noise is just there. I am clueless as to what can I do...
Any ideas...?
Thanks...
