Help me plot the Vt vs L of MOS in 90nm
hr_rezaee
Advanced Member level 3
Iran-Mashhad
Hi
As I know Vt of MOS decrease if it's Length increase.
I need a plot of Vt vs L (min<L<10u) in 90nm.
Could you help me?
Best regards
Re: Vt vs L in 90nm
controversial claim....Please check the following paper, and also read the documents regarding short channel effects... You can find everywhere that threshold voltage decreases with decrease in length.... For voltage sweep use the .data spice command, and plot the data points on microsoft excel...you can also use .alter command together with .op command...
www.insinet.net/jasr/2007/13-16.pdf
    hr_rezaee
Re: Vt vs L in 90nm
thanks
but simulation result is different
Why?
Can anyone test it for me please?
Re: Vt vs L in 90nm
Vt of MOS decrease if it's Length increase in ONE PROCESS
But Vt of MOS decrease if it's Length decrease in Different Process.
Re: Vt vs L in 90nm
Different answers!!!
Re: Vt vs L in 90nm
hr_rezaee said:
Hi
Could you help me?
Best regards
Why?
I don't think so
I think it is easier to turn on with less length.
Vt vs L in 90nm
I think Vth decreases with less length theoretically (because the channel is formed more easily??)
However from my experience, Vth does not vary much with length unless special doping is done.
Re: Vt vs L in 90nm
Yes, I think so. Vth varies much with Vbs, but not very much length and width.
