Help Me Please.... How to convert SPI to I2C
Starhung
Newbie level 2
Newbie level 2
i2c spi converter
Hi all,
Does anyone know how to convert SPI bus to I2C by CPLD or by other
methods?
Please help me. Thank you.
Sincerely,
Star Hung
spi i2c converter
Use an MCU and write a program to bridge them.
i2c to spi converter
Look to microchip MCU, some of them have SPI peripheral and I2C peripheral. The software is then reduced.
beuch.
spi to i2c converter
Thanks for your advice.
The detail situtation describe as follow.
We use TI's DSP, which only provides SPI interface, to capture a picture from a CMOS sensor but the sensor only provides I2C interface for control signal communication. We can't add more MCU between the DSP and the sensor because it's not efficiency. Therefore, we use a CPLD and write a program in it to transfer the control signal from SPI to I2C. Because it's a urgent event, I wonder if anybody have the experience to overcome this question. Must I need to write the program or is there any sample code for that already?
Thank you very much.
Sincerely,
Star
spi to i2c
Look Ubicom (Scenix) SX18/20/28 it is very fast and
have virtual SPI, I2C, RS232 (use it for debugging or logging data) pheripheals.
spi to i2c conversion
we know IIC standard can be capable to run up to 400Khz and so the most cpu in the market today can support this data rate without any problem.
Stark
convert spi to i2c
use chip SC18IS600/601.This is a SPI to I2C converter.
Re: i2c spi converter
Hi all,
methods?
Sincerely,
Star Hung
you can use SPI to I2C converter from silabs : CP2120
regards,
kasirajan G
