Is your requirement for a lab supply? If so, You may want to consider converting a computer power supply over to a universal lab power supply, to power all your projects. I did, and it works just fine. Below is the instructions to convert one over.
may b i didnt understand, coz its so simple to me..........
make sure that, 24V dc supply hv greater than 10A current (ur total current is 10A)
then connect regulator 7815,7805(for 15 and 5 volt respectively)parallely,with suitable capacitor.now using ohms law I=V/R.calculate R required for ur current.
As your input voltage is DC (continuous) and not AC (alternate) you should consider to design a switched mode power supply: i.e. transform the DC input voltage into an AC voltage, apply it on a transformer with several taps and rectify, filter and regulate the output voltages.
See an example:
