dipak.rf
Member level 3
It is a folded cascode opamp and all the baises are fixed.
My problem is when i change bias3 (see in attached figure) by lets say 0.01%(assuming any variation for bias change) the output is changing drastically to half or more, but when i change bias4 (by same amount) the output doesnt change much (very less amount ) even though impedences for both the transistor are same and gm also comparable
Ques1. why much change in output for bias3 variation as compare to bias4?
Ques2. Is it good have this much variation (approximately 50%) for small amount of bias variation?
Ques3. If it is not ok then suggest me a solution?
Thanks in Advance
Thanks in Advance
