You have 4 independent ps channels. You wish to monitor the voltage and current of each channel. So, there are 8 readings to be monitored. You can design a 'manually' triggered 3-bit counter ( 2³ = 8 ) to control the multiplexer.Chuotnha said:I'm still don't know how to connect the select channel button to the circuit. Do I need the timer, counter, decoder circuits, to control the multiplexers, since I need to have only 2 increase/decrease buttons (or 2 rotaries) and one select channel button.
