help me IR Remote sensor 8051
ajit4u
Banned
help me in IR Remote sensor 8051 code
i hv written the code such a way that by capturing the counter value whenever there is a falling edge pulse after pressing Remote key
while pressing the same key my IR sensor value is changing, what is the problem an di can overcome with that problem???
there is one code which is worked on HCS08 but not working on 8051
  • IR.rar
  • old ir code working.rar
Hi friend
First specify, which protocol used in your IR remote.
First change your sensor with same new sensor and used brand new IR remote and check result.
If problem doesn't solve, check your code.
i think, Problem is in your code, not in sensor
Hope this is help you,
Shyam
INDIA
i knows there is some problem with that code.......... if possible write the proper code and pass to me
Some IR protocols use a toggle bit.
It's purpose is to detect repeat button pressing as opposed to a held down button. Therefore each time you press the same button the code will alternate.
If you get the same different code alternating this is not a problem
you probably just have a code using the toggle bit. You just need to decode
it correctly.
If 3 presses produce 3 different codes - you have a problem.
jack
it correctly.
jack
there is nothing wrong in the remote, there is some problem with that code if possible please change the code
First tell us about the protocol of your IR remote,
I worked on RC6 protocol in ccs maybe this will help you if your protocol is also RC6.
i m using NEC protocol
---------- Post added at 11:23 ---------- Previous post was at 11:21 ----------
i was using NEC i didnt get, then started with capture method by controller
Hi friend
I have attached some material for NEC Protocol
I write program for NEC protocol using this material and it work fine.
Shyam
  • NEC Protocol.rar
Hi friend
Shyam
i hv the protocol
that is not working. if u can alter the program means alter it please
i hv written the code by capturing from the PCA and displaying
Re: help me in IR Remote sensor 8051
is der any trick for reading IR remote
can you capture the waveforms and upload it here
find the attachment maybe it will help you
  • Remote_Controls.ppt
can u tel me which protocol is used by seeng schematic
No its a hardware circuit for interfacing IR reciver and all the protocols have same kind of hardware.
you can judge by the waveforms or by writting the program in microcontroller which will be able to detect all the protocols
Reactions: ajit4u
    ajit4u
can u tel me how to write the program?
which compiler you are using for programming?
