Jul 8, 2006 #1 K k1_zav Junior Member level 2 Joined Mar 13, 2005 Messages 23 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,460 Hi there. I have an AT90S8515 and I want to interface it with a 24C32A (I2C EEPROm). functions of Codevision (in its help) do not work properly and I cant send and receive data from eeprom. Is there any body who can help me? Thanks in advance. Regards.
Jul 8, 2006 #2 hr_rezaee Advanced Member level 3 Joined Oct 6, 2004 Messages 747 Helped 109 Reputation 218 Reaction score 24 Trophy points 1,298 Location Iran-Mashhad Activity points 4,025 AVR + I2C Hi do you use pull-up resistors? regards
Jul 9, 2006 #3 shebo Member level 2 Joined Mar 28, 2006 Messages 42 Helped 5 Reputation 10 Reaction score 3 Trophy points 1,288 Location do you ever care? Activity points 1,553 Re: AVR + I2C 1st how are you sure that the function doesn't work ?
Jul 10, 2006 #4 K k1_zav Junior Member level 2 Joined Mar 13, 2005 Messages 23 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,460 AVR + I2C Thanks all. It works. I used pull up resistors. It was because of addressing for EEPROM. its address in memory location is 14 bit and I used 8 bit for addressing. Regards, K1
Jul 10, 2006 #5 shebo Member level 2 Joined Mar 28, 2006 Messages 42 Helped 5 Reputation 10 Reaction score 3 Trophy points 1,288 Location do you ever care? Activity points 1,553 Re: AVR + I2C hi zav, i'm working on the same protocol TWI for I2C EEPROM and it doesn't work do you use interrupt driven Based techinque?
