help me in simulate a circuit in Hspice
matin-kh
Member level 3
Member level 3
iran
View attachment mm018.txt
hi every one
I want to simulate a circuit in hspice and i want to use 0.18 cmos tech that i attached it but i have two question i would be happy if you coul help me :wink:
1- for describing a nmos transistor i use this style:
M1 vout1 vin+ 1 1 NMOS W=10u L=0.5u m=1
the NMOS in the middle of text show the model of transistor but in the mm018.l when it describing models with .model we don't have NMOS for example we have NMOS.0 instead but wehn i use the phrase above it doesn't make me error!!:-| what is the story behind it??
2- as the bjt transistors are defined in mm018.l I want to use npn transistor in my circuit but i don't know how to write it, i write it like below:
Q1 6 vctrl GND npn
but it doesn't work and errors it seems i have to add parameters of npn transistor but i don't know the parameters could you please tell me how can i get the parameters i have no idea about this!!:???:
thanks
matin
excuse me for my bad english my english is not good enough :wink:
You have to decide on one of the transistor models contained in the library, e.g.:
M1 vout1 vin+ 1 1 nmos.1 W=10u L=0.5u m=1
and
Q1 6 vctrl GND NPN10
The various models are shortly described in the preface of the library.
Don't forget to select the required corner model:
* 1)To use these models directly by programming in this style: *
* .lib 'lib_path/lib_name' model_name *
* EX: .lib '/home/user/tsmc/LOGIC/mm018.l' TT *
* for typical 1.8V N,PMOS *
* .lib '/home/user/tsmc/LOGIC/mm018.l' TT_3V *
* for typical 3.3V N,PMOS *
... and don't forget to
.INCLUDE 'lib_path/mm018.l'
thank you very much in advance.
I wrote this:
but it errors like below:
**error** reference 0:npn10 not found
it was referenced in element 0:q1
the emitter width= 0.00 and length= 0.00
the line number was 24
I don't know what's the problem :(
ok thanks. :smile:
yes i correctly include the lib file. i did sth else now i think it works correctly.
