help me in my graduation project ( jammer locator )
amrshata
hi guys i working on a project based on finding a jammer at a certian freq i'm new at that field
so while searching on the internet i find there are several ways for discovery of the position can be realized utilizing range measurements
including received signal strength, time of arrival, time difference of arrival and angle of arrival.
so what tech. is better what freq should i work on that's will be more easy to implement what tools should i use
i'm just at the start so any information will be very helpful , and if there are articles on that fields it will be very helpful
thanks in advance
first of all think about how sensitive you gonna make it then you have to use those tricks accord to level u wanna do
it can be toy like to properly designed those of government agencies like
That's not always the case - sometimes there are more broadband devices (because comms can be spread-spectrum or frequency-hop).
i think it must be good enough , so what tool should i use
yeah but i just build a concept device ,,, and if it's spread i think the jammer will impact the whole wide band .
any help
now i considering working on 433 mhz or 2.4 gigha hz ,,,, and the detection type i will use angle of arrival
so how could i measure the phase difference if i receiving on two antenna's
There is a good book called "microwave passive direction finding" by Lipsky that has about 200 ways of doing it.
You can also access some ham radio pages on DF techniques--something the hams do as a hobby.
I think your project is similiar to the mobile phone location in the mobile telecomm networks. That is very traditional problem.
so ? is it hard ... i just begin reading some book .. some on linear algebra ( eigenvalue and eigenvectors ) and estimation of angle of arrival ,, dunno should i continue or not
The precision of known techonologies can reach about 50m or even less using mobile networks. You first should know various location techonologies.
If you want to chanllenge them, you can go on.
