Re: help on my ICD2
I do not have the manual, but since you can connect to it, you should try to run a self-test first and see what actually fails. If it passes the test, then you really need to check the connections to your target: ICD-2 cable, target socket, etc.
If anything fails during self-test, it is generally either Vdd or Vpp. The test will tell you. Pay close attention to what test fails and what it tells you, such as "target Vdd low", or something like that.
You should then be able to fix the problem. The schematic cannot be very complicated. Look for regulators that can be associated with the voltages involved: 5V and 13V. Check their output. If it is OK, then the problem is most likely the transistor(s) that switch those voltages to the target.
There are a couple of good ICD-2 clones on this board, and I think the schematics are very close to that of your ICD-2. Yoiu should be able to match it, or at least the pins on the micro. That will help you trace the problem, because if you know which pin on the micro drives the Vdd/ Vpp swithc then all you have to do is trace the circuit. Let me know how it goes, maybe I can help.
