ibrahem_mo said:
hi
please help me
i need or so much need
psu circuit 24V 5A
regards
hi,
The question from kiprono meant your input voltage is AC or DC into the psu?
Putting it otherwise, you operate it from the mains or from a DC source?
In case you feed it from the mains, here is a circuit for a linear psu:
https://www.elecfree.com/circuit/power-supply/lm338k-adjustable-power-supply/
If you do not have 120V AC mains voltage in your country but have 220-240V, then the transformer T1 should be chosen accordingly.
If you wish to build a switch mode power supply instead of the above linear one, here is one possibility out of many:
In this case the input voltage should be any DC between 5V - 36V and efficiency is over 90% or so, no need for big heat sink area, unlike in case of the above linear psu circuit. (So any mains transformer of 10V-24V AC output @5A with rectifier bridge and a suitable puffer cap should do.)
Here are some other choices for switch mode ICs you can choose from, of course other manufacturers are also an option:
https://www.linear.com/pc/categoryP...2&referringUrl=/pc/viewCategory.jsp&y=10&x=30
rgds, unkarc
