Help me fix this Matlab code
kosamoza
can any one help me in this code
clc
clear
%BPSK Transmitter
data=randint (1,100000);
data=(2*data)-1;
%AWGN Channel
EbNo_db=0:0.5:10;
No=10.^(0.1*-EbNo_db);
for k=1:length(EbNo_db)
noise =sqrt(No(k)/2).*randn(1,100000);
end
%BPSK Receiver
received = data + noise;
for i=1:length(received)
if(received(i)>=0)
est_bits(i)=1;
else if (received(i)<0)
est_bits=0;
end
end
end
errors = sum (xor(data,est_bits));
Pe(EbNo_db+1)=errors/length(data);
semilogy(EbNo,Pe);
Help with this code
what this? vhdl-ams!
Help with this code
Matlab Coce
& I need help about it
for BPSK Code
Help with this code
what help exactly? u need the code to be explained or debugged?
Help with this code
The code have some errors
when I run the code there is an errror I can'y figure ut
& I want help in this if u could run it & figure out where is the proplem I will be grateful
Re: Help with this code
i was able to debug 2 things in ur code....n there is a 3rd one which is some kind of a logical mistake. as i dont know wat u r upto in mean ur approach i cant help u in that...
but the rest 2 are here...
1.line 23...Pe(EbNo_db+1)=errors/length(data);
the index that u r usin is in double variable form which is not applicable for indexin...so change it to unsigned int by usin ... "EbNo_db=uint16(EbNo_db);" before the above mentioned line.
2. silly one u might have over looked it...the variable name in semilogy should be EbNo_db n not EbNo....
3. the vectors that ur r plotin, ie., in semilogy should be of the same length...this is a logical error...make sure of ur formula n try again. if those two should be plotted one upon the other then they should be of the same length...
