Help me fix errors of an ADC code
justinjohney
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
int adc_result=0;
int ch=0;
int main (void)
//set portC as input and enable the pull up resistor
DDRC=0x00;
PORTC=0xFF;
//set up port D 0-5  as output& C 6,7 as input
DDRD=0x3F;
// Set ADC prescaler to 128 - 125KHz sample rate @ 16MHz
ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
// Set ADC to Free-Running Mode
ADCSRB &=~((1<<ADTS2)|(1<<ADTS1)|(1<<ADTS0)) ;
// Enable ADC
ADCSRA |= (1 << ADEN);
// Enable ADC Interrupt
//ADCSRA |= (1 << ADIE);
// Enable Global Interrupts
 //sei();
// Loop Forever
 	while(1)
		// Set ADC reference to AREF
		// Left adjust ADC result to allow easy 10 bit reading
		//select adc channel 1
		ADMUX=0x00;
			for(ch=0;ch<3;ch++)
		    	// Start A2D Conversions
			   ADCSRA |= (1 << ADSC);
			   //Read the adc result
			   adc_result=ADCW;
		       	_delay_ms(10);
				if(adc_result>970)
					if(ch==0)
						PORTD1=1;
						_delay_ms(50);
							if(adc_result>970)
									PORTB4=1;
					else if(ch==1)
						PORTD2=1;
						_delay_ms(50);
							if(adc_result>970)
									PORTB4=1;
					else(ch==2)
						PORTD2=1;
						_delay_ms(50);
							if(adc_result>970)
									PORTB4=1;
				ADMUX++;
im using avr studio 4 avr gcc compiler
atmega168
Re: adc code shows error
What AVR model are you working with?
AVR Studio 4, GCC compiler
What do you expect to happen?
actually i want to convert three analog signal into digtal simultaneously(with max speed) and compare it with threashold and if any one it is greater than the threashold then a led must glow corresponding to that signal.Moreover if the condition stable for a particular time then there must be get an o/p on a port pin at a particular pin.
What problem(s) are you encountering?
build error,i know the code is not completed
i think now you got it. can you help me?[/code]
code shows error in avr studio
the following code shows error in avr studio, avr gcc compiler.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
#include <avr/io.h>
#include <stdio.h>
//system clock @16MHz
#define F_CPU 16000000
//Global variable
int adc_result[2]={0,0,0};
uint8_t ch=0;
/* PORT INIT */
void port_init (void)
//set portB.1 as output
DDRB |=(1<<PB1);
PORTB&=~(1<<PB1);
//set portC0,1,2, as input and enable the pull up resistor
DDRC &=~(1<<PC0)|~(1<<PC1)|~(1<<PC2);
PORTC |=(1<<PC0)|(1<<PC1)|(1<<PC2);
//set up port D 0-2  as output& D6,7 as input with pull up resistor
DDRD &=~(1<<PC0)|~(1<<PC1)|~(1<<PC2);
DDRD &=~(1<<PD6)|~(1<<PD7);
PORTD |=(1<<PD6)|(1<<PD6);
void init_adc(void)
//ADCSRB &=~((1<<ADTS2)|(1<<ADTS1)|(1<<ADTS0)) ;
//select adc channel 0
//ADMUX=ch;
// Enable ADC
sei();
//Start first conversion
ADCSRA |= (1<<ADSC);
/* Interrupt service routines */
ISR(ADC_vect)
//delay  for discarding first conversion result
//_delay_ms(10);
    switch(ch)
        case 0:
            adc_result[0]=ADCW;
            if(adc_result[0]>862)
                    do
                    PORTD|=(1<<PD0);//glow the led corresponding to signal 1
                    //Start next  conversion with same channel
                    _delay_ms(3);
                    adc_result[0]=ADCW;
                        if(adc_result[0]>887)
                            do
                            adc_result[0]=ADCW;
                            PORTB|=(1<<PB0);//  o/p drive if the state at adc0 exist for a particular time
                            }while (adc_result[0]<970)
                    }while(adc_result[0]<862)
            else if (adc_result[0]<754)
                PORTD|=(1<<PD3);//glow the led corresponding to UV indication
            else
                    if(ch<3)
                        ch++;
                        ADMUX=ch;
                    else
                        ch=0;
                        ADMUX=ch;
            break;
        case 1:
            adc_result[1]=ADCW;
            if(adc_result[1]>862)
                    do
                    PORTD|=(1<<PD1);//glow the led corresponding to signal 2
                    _delay_ms(3);
                    adc_result[0]=ADCW;
                            do
                            adc_result[0]=ADCW;
                            PORTB|=(1<<PB0);//  o/p drive if the state at adc1 exist for a particular time
                            }while (adc_result[1]<862)
                    }while(adc_result[1]<862)
            else if(adc_result[1]<754)
            else
                    if(ch<2)
                        ch++;
                        ADMUX=ch;
                    else
                        ch=0;
                        ADMUX=ch;
            break;
        case 2:
            adc_result[2]=ADCW;
            if(adc_result[2]>862)
                    do
                    PORTD|=(1<<PD2);//glow the led corresponding to signal 3
                    _delay_ms(3);
                    adc_result[0]=ADCW;
                    if(adc_result[2]>887)
                            do
                            adc_result[0]=ADCW;
                            PORTB|=(1<<PB0);//  o/p drive if the state at adc2 exist for a particular time
                            }while (adc_result[2]<862)
                    }while(adc_result[2]<862)
            else if(adc_result[2]<754)
            else
                    if(ch<3)
                        ch++;
                        ADMUX=ch;
                    else
                        ch=0;
                        ADMUX=ch;
            break;
void main()
    port_init();
// Loop Forever
    while(1)
        ADMUX=ch;
        init_adc();
Re: code shows error in avr studio
What kind of error?
You can 't declare an array of two integers and assign three values
I don't think that code like the following can work
DDRC &= ~(1 << PC0) | ~(1 << PC1) | ~(1 << PC2);
This is basically
DDRC = DDRC & (0b11111110 | 0b11111101 | 0b11111011);
But
(0b11111110 | 0b11111101 | 0b11111011) = 0b11111111 so the above will not have any result
What would make sense is
DDRC &=  ~( (1 << PC0) | (1 << PC1) | (1 << PC2) );
The same goes for DDRD
this is applied in a ATmega2560, and this for unit conversions in this case the upper channels are enabled, if you please do it as self CONVERTION or via IRQ, you can manipulate it within the scope of the IRQ
TEM4 = Select_chanel (13);
[INDENT]extern int CHANEL_ADC;
void set_Adac (void)
PRR0 |= (1<<PRADC);                               // power down module adc
PRR0 &= ~(1<<PRADC);                              // power up module adc
ADCSRA |= ((1<<ADPS2) | (1<<ADPS1) | (0<<ADPS0)); // Set ADC prescaler speed
ADMUX  |=  (1<<REFS0) | (0<<REFS1);               // Set ADC referencia
ADCSRB &=  (0<<ADTS2)|(0<<ADTS1)|(0<<ADTS0);
DIDR0 |= ((1<<ADC7D) | (1<<ADC6D) | (1<<ADC5D) | (1<<ADC4D) | (1<<ADC3D) | (1<<ADC2D) | (1<<ADC1D)| (1<<ADC0D)); // Habilitacion de canal
DIDR2 |=  ((0<<ADC15D) | (0<<ADC14D) | (0<<ADC13D) | (0<<ADC12D) | (0<<ADC11D) | (0<<ADC10D) | (0<<ADC9D) | (0<<ADC8D)); // Habilitacion de canal
// ADCSRA |= (1<<ADATE); // AUTO TRIGER
// ADCSRA &= ~(1<<ADIE); // Enable ADC Interrupt
ADCSRA |= (1<<ADEN);    // Enable ADC
// ADCSRA |= (1<<ADSC);  // Start A2D Conversions
int Select_chanel (char chanel)
	ADMUX  &= 0x11100000 ;
	if (chanel <= 7)
    	    ADCSRB &= ~(1<<MUX5);
	    ADMUX |=  chanel;
	if (chanel >= 8)
	    ADMUX  |= chanel - 8 ;
	    ADCSRB |= (1<<MUX5);
	ADCSRA |= (1<<ADIF);
    while (!(ADCSRA & (1<<ADIF)));
     uint16_t ADC_rslt = (ADCL);
     ADC_rslt += (ADCH << 8);      // for all 10 bits
     return ADC_rslt;
}[/INDENT]
The do - while loops are missing semi colons. this is basically what you need to build.
do {
} while ( condition );
how can i make my system clock into 16MHz in atnega168?
code shows error again
avr studio 4
avr gcc compiler
#include <avr/io.h>
#include <stdio.h>
//system clock @1MHz
#define F_CPU 1000000
//Global variable
int adc_result[3]={0,0,0};//for storing the adc out put
uint8_t ch=0;
/* PORT INIT */
//set portB.1 as output drive for relay
DDRB |=(1<<PB1);
PORTB&=~(1<<PB1);
//set portC0-4 as input and enable the pull up resistor
DDRC &=~((1<<PC0)|(1<<PC1)|(1<<PC2)|(1<<PC3)|(1<<PC4));// ADC i/p R,B,Y & Gnd, neutral
PORTC |=((1<<PC0)|(1<<PC1)|(1<<PC2)|(1<<PC3)|(1<<PC4));
//set up port D 0-3  as output
DDRD &=~((1<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3));//o/p led for R,B,Y and GLP
void init_adc(void)
// Set ADC prescaler to 8 - 125KHz sample rate @ 1MHz
ADCSRA |= ((1 << ADPS1) | (1 << ADPS0));
// Enable ADC
sei();
/* Interrupt service routine for Analog comparator*/
ISR(ANA_COMP)
ISR(ADC_vect)
//_delay_ms(10);
   switch(ch)
      case 0:
         adc_result[0]=ADCW;
         if(adc_result[0]>823) //checking for vge >265V
               do
               _delay_ms(3);
               //wait for coversion to be completed
               adc_result[0]=ADCW;
                  if(adc_result[0]>837) //checking for vge >270V
                     do
                     adc_result[0]=ADCW;
                     PORTB|=(1<<PB1);//  o/p drive ON if the state at adc0 exist for a particular time
                     }while (adc_result[0]<823);//do until the vge reduced to 265V
               }while(adc_result[0]>823);
               PORTD&=~(1<<PD0);//off the led corresponding to signal 1
               PORTB&=~(1<<PB1);// o/p drive off for ON the relay
         else if (adc_result[0]<713)//checking for vge <230V
               do
                  adc_result[0]=ADCW;
               }while(adc_result[0]<713);//do until vge >230V
               PORTD&=~(1<<PD3);//off the led corresponding to UV indication
         else
               if(ch<3)
                  ch++;//change adc channel
                  ADMUX=ch;
         break;
      case 1:
         adc_result[1]=ADCW;
         if(adc_result[1]>823)//checking for vge >265V
               do
               _delay_ms(3);
               adc_result[0]=ADCW;
                     do
                     adc_result[0]=ADCW;
                     PORTB|=(1<<PB1);//  o/p drive if the state at adc1 exist for a particular time
                     }while (adc_result[1]>862);
               }while(adc_result[1]>823);
               PORTD|=(1<<PD1);//off the led corresponding to signal 2
         else if(adc_result[1]<713)//checking for vge <230V
               do
                  adc_result[0]=ADCW;
         else
               if(ch<3)
                  ch++;
                  ADMUX=ch;
         break;
      case 2:
         adc_result[2]=ADCW;
         if(adc_result[2]>862)//checking for vge >265V
               do
               _delay_ms(3);
               adc_result[0]=ADCW;
               if(adc_result[2]>837) //checking for vge >270V
                     do
                     adc_result[0]=ADCW;
                     PORTB|=(1<<PB1);//  o/p drive if the state at adc2 exist for a particular time
                     }while (adc_result[2]<862);
               }while(adc_result[2]<862);
         else if(adc_result[2]<713)//checking for vge <230V
               do
                  adc_result[0]=ADCW;
         else
               if(ch<3)
                  ch++;
                  ADMUX=ch;
         break;
// GLP
      case 3:
            adc_result[3]=ADCW;
            ADMUX=0x04;//select adc 4
            adc_result[4]=ADCW;
               if((adc_result[3]-adc_result[4])>31)
                  PORTD|=(1<<PD3);//ON the led corresponding to GLP indication
                  do
                     ADMUX=0x03;//select adc 3
                     adc_result[3]=ADCW;
                     adc_result[4]=ADCW;
                        if((adc_result[3]-adc_result[4])>38)
                  }while((adc_result[3]-adc_result[4])>31);
                  PORTD&=~(1<<PD3);//OFF the led corresponding to GLP indication
                  PORTB&=~(1<<PB1);// off the  o/p drive
int main(void)
   port_init();
   //discarding the first adc result
   ADMUX=ch;
// Loop Forever
    while(1)
      init_adc();
looking at your code there are some oddities that do not understand.
for example in the code main () {} put in a loop while (), init adac, this does not make much sense, once you tell the ADC that resolves their just right through the interruption is not necessary that put inside the loop, the while loop should be empty.
Another detailed discussion, is that the service interruptions ADC put some time delays that exceed the timing of the ADC. I think you should do this out of the ADC service, perhaps with a timer loop checking the results on the response time to pretend, so you would have two elements in the program running freely
and on the other hand you say that the compiler gives or indicates errors, why not also posts the error to see what or what is the response you get from the compiler
Hello!
Some remarks: (including a summary of what has been said above)
- Please provide a full description of your errors (compiler's error code, error string, error line number, etc...)
- Don't change subject. After your first error report, you write suddenly "how can i make my system clock into
16MHz in atnega168?", and we don't know if the first problem has been solved or not...
- Looking at your code, you use a lot of hard-coded values. For example the number 823 happens 5 times.
what happens if the value is wrong? You correct it. But you have to correct it at 5 places. Why not defining it
like this : #define ADCVAL_265 823, and then use ADCVAL_265 in your code instead of 823. If the value is
wrong, you can correct it only once in the define statement.
- Looking at your code again, you have a huge ISR function with a switch on the channel number. But for all your
channel cases, you do the same processing. For example you write:
switch(ch) {
case [COLOR="#FF0000"]0:[/COLOR]
adc_result[[COLOR="#FF0000"]0[/COLOR]]=ADCW;
case [COLOR="#FF0000"]1[/COLOR]:
adc_result[[COLOR="#FF0000"]1[/COLOR]]=ADCW;
case [COLOR="#FF0000"]2[/COLOR]:
adc_result[[COLOR="#FF0000"]2[/COLOR]]=ADCW;
case [COLOR="#FF0000"]3[/COLOR]:
adc_result[[COLOR="#FF0000"]3[/COLOR]]=ADCW;
This can be factorized as :
adc_result[ch] = ADCW;
switch(ch) {
case 0:
... code specific to case 0
case 1:
...code specific to case 1
case 2:
...code specific to case 2
case 3:
...code specific to case 3
Then this part is very recurrent:
               adc_result[0]=ADCW;
I think you could factorize even further and end up in a half-page efficient code.
- Last, but no least, you may consider to say "hello", "please", "thank you" to people who reply, etc...
Dora.
thanx Mr. doraemon
here is my new code. can u predict its behaviour
#include <avr/io.h>
#include <stdio.h>
//#define F_CPU 1000000 //system clock @1MHz
//Global variable
int adc_result[5]={0,0,0,0,0};//for storing the adc out put
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
DDRB |=(1<<PB1);//set portB.1 as output drive for relay
PORTB&=~(1<<PB1);//initially set 0 as o/p drive
DDRB |=(1<<PB0);//error occur
//set portC0-4 as i/p with pull up resistor
//set up port D 0-4  as output
DDRD &=~((1<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3)|(1<<PD4));//o/p led for R,B,Y and GLP
void init_adc(void)
ADCSRA |= ((1 << ADPS1) | (1 << ADPS0));// Set ADC prescaler to 8 - 125KHz sample rate @ 1MHz
ADCSRA |= (1 << ADEN);  // Enable ADC
ADCSRA |= (1 << ADIE); // Enable ADC Interrupt
ADCSRA |= (1<<ADSC);//start conversion
while (!(ADCSRA & (1<<ADIF)));//wait for coversion to be completed
void init_glp(void)
	i=ch;
	ADMUX=ch;
	init_adc();
	adc_result[i]=ADCW;
int main(void)
	i=ch;
	port_init();
	ADMUX=ch;
	init_adc();
	ADCSRA |= (1<<ADSC);//discarding the first adc result
// Loop Forever
 	while(1)
			ch=0;
			init_adc();
			if(ch<3)
				for(ch=0;ch<3;ch++)
						ADMUX=ch;
						init_adc();
						adc_result[i]=ADCW;
						if (adc_result[i]>795)//checking for 265V
							PORTD=y;//OV indication led on
							_delay_ms(1);
							init_adc();
							adc_result[i]=ADCW;
								if(adc_result[i]>810)//checking for 270V
									do
										PORTB|=(1<<PB1); //  o/p drive ON
										init_adc();
										_delay_ms(1);
										adc_result[i]=ADCW;
									}while(adc_result[i]>795);
									PORTD=0x00;//off the OV indicator led
						else if(adc_result[i]<690)//checking for 230V
								do
									PORTD|=(1<<PD3);// on the led corresponding to UV indication
									init_adc();
									adc_result[i]=ADCW;
								}while(adc_result[i]<690);//checking for 230V
						y++;
					y=0;
			else if((2<ch)&&(ch<5))
				ch=3;
				init_glp();
				ch++;
				init_glp();
				k=(adc_result[4]-adc_result[3]);
				if(k>30)//checking for 230V
					PORTD|=(1<<PD4);//ON the led corresponding to GLP indication
					_delay_ms(1);
					ch=3;
					init_glp();
					ch++;
					init_glp();
					if(k>45)//checking for 15V difference
						do
							ch=3;
							init_glp();
							ch++;
							init_glp();
						}while(k>30);//checking for 15V difference
						PORTD&=~(1<<PD4);//OFF the led corresponding to GLP indication
			else
				PORTB|=(1<<PB0);
Hello!
Some other remarks:
- Usually you initialize ADC at the beginning of the program and never touch it again (except if you have to
change ADC sampling characteristics). In your program you repeatedly calls it in a loop, which makes absolutely
no sense. For example, you call port_init only once, which is the right thing to do. Why do you repeatedly
call the ADC initialization?
- Apparently your initialization actually makes a conversation. An initialization should only initialize. I would
keep the 3 first lines of the init and use the two last lines in a function like this:
uint16 Convert(void) {
	return ADCW;
NB: I don't know AVR, so it may not be uint16 but another type. Adjust to the right type.
- I don't know anything about AVR, but apparently you setup interrupts (line 3 of your init_adc function). But
you don't define an interrupt routine.
- I don't understand this part:
		if(ch<3) {
			for(ch=0;ch<3;ch++) {
Usually you don't iterate on a variable you have just tested. Maybe it works, but you may end up making
action that you don't want in this part of the program.
Could you explain in plain english what you are planning to do?
I understand that you are measuring a voltage and that you want to take actions according to he voltage
but I don't see clearly what it should do. But looking at the redundancies, I'm almost sure that the core can
be done in a readable way with a smaller code.
Could you accurately and in plain english describe what you want to do?
Dora.
Mr. doraemon ,
i have 5 ac signal which must be contineously checked , The first 3 signal need to be checked for undervoltage and over voltage. if a signal above a threshold1 then an OV indicator must glow. if the OV indicator glow,Again we checked that signal with a threshold2 which is higher than threashold1. if that is true i need an out put in PB1 until the voltage reduces below threashold1.
if the signal is not greater than threshold1, then it must test fo.r under voltage threahold3.if our signal under than threshold3 then UV indicator glow and again it checked for threshold 4 (Remember, threshold4<threshold 3)and if that is true then i need a o/p at PB1.
if our signal not in the range of above 2 situation then the channel must change and check these condition for other 2 signals.
if all is correct then i want to compare my 4th and 5th signal each other and if the difference b/w that two signal > threshold 5 and an indication will glow and check again for threshold 6 and if it is greater than threshold 6 then i want an o/p at PB1 until the diference go under threashold7.
all these process repeated .
my updated code is here:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
fine F_CPU 1000000UL //system clock @1MHz
#include <avr/io.h>
#include <stdio.h>
//Global variable
uint16_t adc_result[5]={0,0,0,0,0};//for storing the adc out put
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
DDRB |=(1<<PB0);//error occur pin
DDRD &=~((1<<PD0)|(1<<PD1)|(1<<PD2)|(1<<PD3)|(1<<PD4));//o/p led for OV,UV and GLP
void init_adc(void)
void read_adc(void)
    _delay_ms(1);
    while ((ADCSRA & (1<<ADSC)));//wait for coversion to be completed
    adc_result[i]=ADCW;
void init_glp(void)
    i=ch;
    ADMUX=ch;
    read_adc();
    adc_result[i]=ADCW;
void glp(void)
    init_glp();
    ch++;
    init_glp();
int main(void)
    i=ch;
    port_init();
    ADMUX=ch;
    init_adc();
    read_adc();
// Loop Forever
    while(1)
            ch=0;
            if(ch<3)
                for(ch=0;ch<3;ch++)
                        ADMUX=ch;
                        read_adc();
                        if (adc_result[i]>792)//checking for 255V
                            PORTD|=(1<<PD0);//OV indication led on
                            _delay_ms(1);
                            read_adc();
                                while(adc_result[i]>823)//checking for 265V
                                    do
                                        read_adc();
                                    }while(adc_result[i]>792);//Should be in the state off until voltage reaches under 255V
                        else if(adc_result[i]<621)//checking for 200V
                                    read_adc();
                                    while(adc_result[i]<495)// checking for 160V
                                        do
                                            read_adc();
                                        }while(adc_result[i]<543);  _delay_ms(1);
                                PORTD&=~(1<<PD3);//Off the UV indicator
                        i++;
                    ch++;
//GLP SECTION
                    ch=3;
                    glp();
                    if(k>22)//checking for 7V
                        _delay_ms(1);
                        ch=3;
                        glp();
                        if(k>22)//checking for 9V difference
                            do
                                ch=3;
                                glp();
                            }while(k>3);//Should be in the state off until voltage reaches under 7V
                ch=0;
            else
                PORTB|=(1<<PB0);
Hello!
So now that you have your spcecs written, you should proceed to implementation,
but I would recommand a more functional approach.
1. You have thresholds, but they don't appear in your code. The first thing is
to define them:
#define THRES_255V 792
#define THRES_265V 823
#define THRES_200V 621
#define THRES_160V 495
#define THRES_7V 22
etc...
And don't write the values again in your code.
Now you can notice that if you write:
if(adc_result[something] > THRES_255V) {
Then you don't even have to comment the code because THRES_255V says everything.
2. Now according to your specs, you have 5 AC signals that you need to measure
continuously. I think it should be like this:
[some initializations]
while(1) {
	read_all_adc_values();
	[do the processing here but don't read the 5 values again until the
	current signal evaluation is finished]
3. There are inconsistencies in your program. Example:
		ch=0;
		if(ch<3) {
Do you think there is any chance that your if is not entered? Remove the if statement,
it's useless (I mean, don't remove the statements in the if, remove the if line only
and of cours the closing bracket. And also remove the else part completely, including
statements in "else {" because these statements will never be reached.
4. There is a logical issue in your code. You say:
"if a signal above a threshold1 then an OV indicator must glow. if the OV indicator
if that is true i need an out put in PB1 until the voltage reduces below threashold1."
Now let's assume your signal rises over threshold1 and stays there (i.e. does not
go over threshold 2), then you will block your program and you will not read other
signals until this condition is true.
Conclusion: you shouldn't do like this. You should do as I wrote above, read the 5
signals, process, read 5 signals, process, etc...
This way the program will be kept very simple.
Dora.
thank you Mr. Dora, your advice help me a lot.
I just updated the code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
# define F_CPU 1000000UL //system clock @1MHz
#define THRES_175V  543
#define THRES_9V    28
#define THRES_7V    22
#include <avr/io.h>
#include <stdio.h>
//Global variable
uint8_t ch=0;
uint8_t y=0;
uint8_t i=0;
int k=0;
/* PORT INIT */
void init_adc(void)
void read_adc(void)
    i=ch;
    _delay_ms(1);
    adc_result[i]=ADCW;
void init_glp(void)
    ADMUX=ch;
    read_adc();
void glp(void)
    init_glp();
    ch++;
    init_glp();
int main(void)
    i=0;
    i=ch;
    port_init();
    ADMUX=ch;
    init_adc();
    read_adc();
// Loop Forever
    while(1)
            PORTD&=~(1<<PD0);//OV indication led off
            if(ch<3)
                for(ch=0;ch<3;ch++)
                        ADMUX=ch;
                        read_adc();
                        if (adc_result[i]>THRES_255V)//checking for 255V
                            _delay_ms(1);
                            read_adc();
                                while(adc_result[i]>THRES_265V)//checking for 265V
                                    do
                                        read_adc();
                                    }while(adc_result[i]>THRES_255V);//Should be in the state off until voltage reaches under 255V
                        else if(adc_result[i]<THRES_200V)//checking for 200V
                                    read_adc();
                                    while(adc_result[i]<THRES_160V)// checking for 160V
                                        do
                                            read_adc();
                                        }while(adc_result[i]<THRES_175V);
                ch++;
//GLP SECTION
                    ch=3;
                    glp();
                    if(k>THRES_7V)
                        _delay_ms(1);
                        ch=3;
                        glp();
                        if(k>THRES_9V)
                            do
                                ch=3;
                                glp();
                            }while(k>THRES_7V);
                    else
                        PORTD&=~(1<<PD4);//off the led corresponding to GLP indication
                ch=0;
            else
                PORTB|=(1<<PB0);// Error in microcontroller programming
                ch=0;
Hello!
Are you reading what I write?
I told you that for each loop, you should read the ADC ONCE for ALL THE CHANNELS and then do the
processing. If you permanently do local loops with read_adc in the whole software, then you cannot
write a meaningful program. You will for sure be locked at some place. So for the last time:
 	while(1) {
 	 	read_your_5_ADC_values_at_once();  // Might sound redundant, but: READ THE ADC ONCE PER LOOP ONLY!!!!!
 				// At that point, your add_values array should be filled with 5 new values.
	 	do_your_processing_here_and_dont_touch_the_ADC_here();
Beside this, you should look at your code first from the highest level:
	if(ch < 3) { // This will be valid for channels 0, 1, 2
	//GLP SECTION
	else if((2 < ch) && (ch < 5)) { // This will be valid for channels 3, 4
	else { // As you have only 5 channels (0 to 4), what is the meaning of this one?
Now one programming hint: in a program, if you have too many indent levels, you are doing something wrong.
Your mileage may vary, but for instance in my case, I don't remember having written programs with more
than, say, 3~4 indent levels. You have 7, this is way too much. At least for the complexity of what you want
to do. One may disagree, but I think that if one function takes more than one page (i.e. if you cannot view it
in a single screen), then you have to split it. Most of the screens are about 1000 ~ 1200 pixels high now.
This gives you about 50 lines, depending on the font.
And you should avoid to pile up the while / do while as you do.
Example:
	while(adc_result[i] > THRES_265V) { //checking for 265V
		do {
			PORTB |= (1 << PB1); //  o/p drive ON
			read_adc();
		while(adc_result[i] > THRES_255V); //Should be in the state off until voltage reaches under 255V
		PORTD = 0x00; //off the OV indicator led
		PORTB &= ~(1 << PB1); // o/p drive off
I really don't understand what this does.
Dora.
How can i program my code to atmega 168 using universal microcontroller kit?which memmory is used for that?eeprom or flash?
Hello!
Before replying this question, did you solve your other software problems? Dos your software work now?
Dora.
ya Mr.Dora
thank you for your help
