Re: Inverter design
If you are simulating the inverter
connect the output with the input (physically or virtually ) then try to adjust the aspect ration until the voltage of this point (input tied to the output) is equal to VDD/2
Then you have same strength PMOS and NMOS, it will keep the same input duty cycle if you use even number of successive inverters, or (1-Duty Cycle) if you have odd number of successive inverters.
Try it & tell me the results
best regards,
Rania
