london
Member level 4
I am using MSP430F449 to communicate RTC (PCF8563) by software I2C. Here I am giving the I2C coding for PIC picrocontroller. Pls any one convert me to use in my micro controller. Here I am attaching the circuits of mine and the given cord circuit.
In my circuit no voltage source is connected at SDA, SCL lines.
the code,
This example shows how to implement a software I2C master, including clock stretching. It is written in C for the PIC processor, but should be applicable to most processors with minor changes to the I/O pin definitions. It is suitable for controlling all of our I2C based robot modules. Since the SCL and SDA lines are open drain type, we use the tristate control register to control the output, keeping the output register low. The port pins still need to be read though, so they're defined as SCL_IN and SDA_IN. This definition and the initialization is probably all you'll need to change for a different processor.
#define SCL TRISB4 // I2C bus
#define SDA TRISB1 //
#define SCL_IN RB4 //
#define SDA_IN RB1 //
To initialize the ports set the output resisters to 0 and the tristate registers to 1 which disables the outputs and allows them to be pulled high by the resistors.
SDA = SCL = 1;
SCL_IN = SDA_IN = 0;
We use a small delay routine between SDA and SCL changes to give a clear sequence on the I2C bus. This is nothing more than a subroutine call and return.
void i2c_dly(void)
The following 4 functions provide the primitive start, stop, read and write sequences. All I2C transactions can be built up from these.
void i2c_start(void)
SDA = 1; // i2c start bit sequence
i2c_dly();
SCL = 1;
i2c_dly();
SDA = 0;
i2c_dly();
SCL = 0;
i2c_dly();
void i2c_stop(void)
SDA = 0; // i2c stop bit sequence
i2c_dly();
SCL = 1;
i2c_dly();
SDA = 1;
i2c_dly();
unsigned char i2c_rx(char ack)
char x, d=0;
SDA = 1;
for(x=0; x<8; x++) {
d <<= 1;
do {
SCL = 1;
while(SCL_IN==0); // wait for any SCL clock stretching
i2c_dly();
if(SDA_IN) d |= 1;
SCL = 0;
if(ack) SDA = 0;
else SDA = 1;
SCL = 1;
i2c_dly(); // send (N)ACK bit
SCL = 0;
SDA = 1;
return d;
bit i2c_tx(unsigned char d)
char x;
static bit b;
for(x=8; x; x--) {
if(d&0x80) SDA = 1;
else SDA = 0;
SCL = 1;
d <<= 1;
SCL = 0;
SDA = 1;
SCL = 1;
i2c_dly();
b = SDA_IN; // possible ACK bit
SCL = 0;
return b;
the code,
SDA = SCL = 1;
void i2c_dly(void)
i2c_dly();
SCL = 1;
i2c_dly();
SDA = 0;
i2c_dly();
SCL = 0;
i2c_dly();
void i2c_stop(void)
i2c_dly();
SCL = 1;
i2c_dly();
SDA = 1;
i2c_dly();
char x, d=0;
SDA = 1;
d <<= 1;
do {
SCL = 1;
i2c_dly();
if(SDA_IN) d |= 1;
SCL = 0;
if(ack) SDA = 0;
else SDA = 1;
SCL = 1;
SCL = 0;
SDA = 1;
return d;
char x;
static bit b;
for(x=8; x; x--) {
if(d&0x80) SDA = 1;
else SDA = 0;
SCL = 1;
d <<= 1;
SCL = 0;
SDA = 1;
SCL = 1;
i2c_dly();
SCL = 0;
return b;
