Help me convert DXF files to Gerber file using Gerbtool
Re: DXf Files to Gerber
The DXF input file has just numbers without units. After loading the DXF file, you have to tell Gerberwizard the units that you used. It seems that you have specified the wrong units.
Best regards
Volker
Re: sonnet dxf to extended gerber file converter
Thanks to Manjunatha_hv,
Here's the uploaded file.
After downloading, unpack the data to a local directory. Install the translator by executing the file "SETUP.EXE" in the directory to which you unpacked the download.
I could not able to install it.....do not know where I am going wrong. would apreciate if could help. Thanks
---------- Post added at 14:59 ---------- Previous post was at 14:57 ----------
I could no able to install it. Would appreciate if you could help. Do not know where I am going wrong.
Unfortunately, the setup program is not compatible with some new Windows versions.
Thanks hips. I am only using windows xp pro. Do you know any other software that would convert dfx filer to a gerber file. Help require very urjent. Thanks again
The program should install and run on Windows XP 32bit. I am pretty sure about that because I'm the programmer.
What exactly is the installation problem that you see?
Thanks . It worked. I was trying to insatall in UNIX workstations..
After I have converted to gerber file, any recomended free software to open the file, tried
ViewMate - Free Gerber Viewer
www.pentalogix.com/Download/download.html
GC Prevue
GraphiCode - Software Innovations for Electronics Manufacturing - Home
Did not work, your help would be apreciated.
thanks
I am using Windows 7 64 bit, is there a version which, do you know of any .dxf to gerber file converters?
Thank you
Thank you
Try Sonnect-DXF to Extended Gerber RS274X
Try using viewmate to convert DXF to GERBER
https://www.pentalogix.com/dxf-file-converter.php
