Help me build FM-PLL transmitter with LMX2315
fuat_09
Junior Member level 1
TURKEY
I want to build fm-pll transmitter with lmx2315.But I can't schema.help me please.
Thanks
fuat
Re: LMX2315 help
You can connect a varactor diode at the crystal. You can apply your modulation to the varactor diode and it will move the crystal frequency(FM). You must set the loop bandwidth of the PLL to be lower than the lowest modulation frequency you wish to pass. That is the simplest way to make fm with a PLL.
Re: LMX2315 help
thank you toonafishy
can I to control lmx2315 to use a PIC ?
Re: LMX2315 help
I'm not a software person but it looks simple enough, clock, data and latch.
Re: LMX2315 help
WHat exactly do you need???
Re: LMX2315 help
I'want to build a one frequency transmitter with lmx2315.
only lmx2315 to use(or lmx2315 and PIC).
is this possible?
I wonder?
