umang
Junior Member level 2
Please do answer the following questions, if ny1 knew it....
> the internal resistance of the ammeter is.....
> hay bridge is used for the measurement of ....
> when modulation frequency is doubled, modulation index is halved and the modulation voltage remains constant, the type of modulation is called.....
> impedance inversion may be obtained with:
-short circuited stud
-open circuited stud
-quarter wave line
-half wave line
> high frequency waves are:
-observed at F2 layer
-reflected by D layer
-capable of long distance communication
-affected by solar cycle
> signal strength received by geosychronous satellites is of order of:
-milliwatts
-watts
-pico watts
-killo watts
> class B amplifier is biased:
-just above the load line
-just at cut off
-nearly twice the cut off
-at midpoint of load line
-so that Ib equals Ic
-quarter wave line
-half wave line
-milliwatts
-watts
-pico watts
-killo watts
-just at cut off
