I'm using a NMOS input. So, if I use a PMOS input it should work with the grounded positive input? Or should I use the VCM = 1.65V?
Both methods should work.
If I use an OTA with the input PMOS can I use GND instead of VCM to achieve the second result?
I'll try using a PMOS input then. Thanks for the tip.Yes, I think so, as in this case the OTA's input common mode range (ICMR) will include GND .
In this case the ICMR of your special OTA topology doesn't contain GND, i.e. if one of the inputs receives GND potential, the OTA doesn't work within its linear range any more.I used an OTA with the PMOS input and the result is the same. When I use VCM the configuration of integrator works, but if I use GND don't.
No, this wouldn't help. I suggest you use the VCM method; it's a virtual GND anyway.Using a rail-to-rail OTA, I'll obtain success in to achieve the desired result?
This, e.g. is the case if you use feedback either directly or via a resistive divider from the output to the inverting input: if your output is unable to get completely down to GND, the OTA feedback loop cannot bring down the inverting input to GND either, hence the circuit gets out of its linear operation range. To avoid this, you'd have to redesign your OTA topology completely.
I think this isn't possible without using a negative voltage supply against GND .How can I start the integration from 0 V?
