Help in Microwave Office (MWO) - adaptation of antenna
cuongtran
Full Member level 3
WhiteHouse
Hi all,
If anyone work with MWO please help me to find out the adaptation of the antenna array below, by MWO, ( in f=0-70GHz), I can not find the good circuit in MWO neither good adaptation of array, so I need your help, thanks very much,
You can use the substrate which has eps=2.5, h=0.8mm, conductor is Cu.
Please upload here your MWO file created the equivalent circuit, thank you very much !!!!
ps- we excite the port 50 Ohm at the head of stripline.
Hello,
Find attached is the MWO project file of the requested antenna using EMSight simulations & Circuit Schematic model...
---manju---
    cuongtran
Manjunatha,
Thank you very much, i appréciate your post, but may you help me to save the file in the version 7.05 plz; my version is awr7.05 so it cannot open your file, thanks.
ps- what MWO'version you have? thanks
Hello cuongtran,
Yes here is the MWO v7.0 files...
I use the latest MWO 2009 v9.0
---manju---
    cuongtran
