Aug 8, 2011 #1 H hamid_twaty Newbie level 4 Joined Aug 8, 2011 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,315 hello all; how to connect three slave Mc68hc11 microcontroller to the Master please help me
Aug 8, 2011 #2 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 Hi, You can use a SPI bus to implement a master/slave communication between multiple 68HC11s. Synchronous Serial Communications on the 68HC11 - Demos just such an implementation. The above example should get you started in the right direction. Reference, PDF example, pg8, Section 9: SPI Communication Introduction to the 68HC11(F1) BigDog
Aug 8, 2011 #3 H hamid_twaty Newbie level 4 Joined Aug 8, 2011 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,315 thank you very much for your prompt response
