bashekmagroh
hi guys ..
I have problem with designing the low pass filter using microwave office ...
the objective is as follow :
return loss 9 db over bassband frequency of 0-2 GHZ
attenuation 20 db at the stop band edge of 3 GHZ
source and load termination 50 ohm
maximum line impedance 90 and minimum is 25
Fabrication materila RT 5880 Duroid .
i started design this filter by using the microwave office . and i started with the lumped element design and i get all the result correct .
then i move to the design in order of high and low frequency . and i got it done ..
then when i moved to the microstrip design i face a problem with the graph which i couldnt get the S11 correctly ... it shows me totally diffrent shape of the graph ....
the microstrip graph is graph 2 ...
and here is the link of the microwave office file ....
Untitled Project.emp
hopefully someone can help and thanks in advance
