Help in LCD program delay function
WhyWhy
Member level 4
Member level 4
Hi Guys,
I Trying to compile this program but it got error..
HTML:
Warning [359] C:\Users\WhyWhy\Desktop\Interfacing LCD with PIC Microcontroller - Hi Tech C\8 Bit\code.c; 30.48 illegal conversion between pointer types
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.70\bin\picc.exe" "-olcd pic.cof" "-mlcd pic.map" --summary=default --output=default code.p1 --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
(1273) Omniscient Code Generation not available in Lite mode (warning)
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode)  V9.70
Copyright (C) 2009 Microchip Technology Inc.
Warning [1355] C:\Users\WhyWhy\Desktop\Interfacing LCD with PIC Microcontroller - Hi Tech C\8 Bit\code.c; 33. inline delay argument too large
Warning [1355] C:\Users\WhyWhy\Desktop\Interfacing LCD with PIC Microcontroller - Hi Tech C\8 Bit\code.c; 39. inline delay argument too large
Warning [1355] C:\Users\WhyWhy\Desktop\Interfacing LCD with PIC Microcontroller - Hi Tech C\8 Bit\code.c; 46. inline delay argument too large
Error   [800] lcd pic.as; 998. undefined symbol "__delay"
Main.h
#include<htc.h>
#include<pic.h>
#define RS RB6
#define EN RB7
#define D0 RC0
#define D1 RC1
#define D2 RC2
#define D3 RC3
#define D4 RC4
#define D5 RC5
#define D6 RC6
#define D7 RC7
#define _XTAL_FREQ 8000000
#include "lcd.h"
void main()
 int i;
  TRISB = 0x00;
  TRISC = 0x00;
  Lcd4_Init();
  while(1)
    Lcd4_Set_Cursor(1,1);
    Lcd4_Write_String("LCD Hello World");
    for(i=0;i<15;i++)
      __delay_ms(1000);
      Lcd4_Shift_Left();
    for(i=0;i<15;i++)
      __delay_ms(1000);
      Lcd4_Shift_Right();
    Lcd4_Clear();
    Lcd4_Set_Cursor(2,1);
    Lcd4_Write_Char('e');
    Lcd4_Write_Char('S');
    __delay_ms(2000);
lcd.h
//LCD Functions
#include <htc.h>
#ifndef D0
#define D0 RB0
#define D1 RB1
#define D2 RB2
#define D3 RB3
#endif
//LCD 8 Bit Interfacing Functions
void Lcd8_Port(char a)
	if(a & 1)
		D0 = 1;
	else
		D0 = 0;
	if(a & 2)
		D1 = 1;
	else
		D1 = 0;
	if(a & 4)
		D2 = 1;
	else
		D2 = 0;
	if(a & 8)
		D3 = 1;
	else
		D3 = 0;
	if(a & 16)
		D4 = 1;
	else
		D4 = 0;
	if(a & 32)
		D5 = 1;
	else
		D5 = 0;
	if(a & 64)
		D6 = 1;
	else
		D6 = 0;
	if(a & 128)
		D7 = 1;
	else
		D7 = 0;
void Lcd8_Cmd(char a)
  RS = 0;             // => RS = 0
  Lcd8_Port(a);             //Data transfer
  EN  = 1;             // => E = 1
  __delay_ms(5);
  EN  = 0;             // => E = 0
Lcd8_Clear()
	  Lcd8_Cmd(1);
void Lcd8_Set_Cursor(char a, char b)
	if(a == 1)
	  Lcd8_Cmd(0x80 + b);
	else if(a == 2)
		Lcd8_Cmd(0xC0 + b);
void Lcd8_Init()
	Lcd8_Port(0x00);
	RS = 0;
	__delay_ms(25);
	///////////// Reset process from datasheet /////////
  Lcd8_Cmd(0x30);
__delay_ms(5);
  Lcd8_Cmd(0x30);
	__delay_ms(15);
  Lcd8_Cmd(0x30);
  Lcd8_Cmd(0x38);    //function set
  Lcd8_Cmd(0x0C);    //display on,cursor off,blink off
  Lcd8_Cmd(0x01);    //clear display
  Lcd8_Cmd(0x06);    //entry mode, set increment
void Lcd8_Write_Char(char a)
   RS = 1;             // => RS = 1
   EN  = 1;             // => E = 1
  __delay_ms(4);
   EN  = 0;             // => E = 04
void Lcd8_Write_String(char *a)
	int i;
	for(i=0;a[i]!='\0';i++)
	 Lcd8_Write_Char(a[i]);
void Lcd8_Shift_Right()
	Lcd8_Cmd(0x1C);
void Lcd8_Shift_Left()
	Lcd8_Cmd(0x18);
//End LCD 8 Bit Interfacing Functions
//LCD 4 Bit Interfacing Functions
void Lcd4_Port(char a)
	if(a & 1)
		D4 = 1;
	else
		D4 = 0;
	if(a & 2)
		D5 = 1;
	else
		D5 = 0;
	if(a & 4)
		D6 = 1;
	else
		D6 = 0;
	if(a & 8)
		D7 = 1;
	else
		D7 = 0;
void Lcd4_Cmd(char a)
	Lcd4_Port(a);
	EN  = 1;             // => E = 1
  __delay_ms(4);
  EN  = 0;             // => E = 0
Lcd4_Clear()
	Lcd4_Cmd(0);
	Lcd4_Cmd(1);
void Lcd4_Set_Cursor(char a, char b)
	char temp,z,y;
	if(a == 1)
	  temp = 0x80 + b;
		z = temp>>4;
		y = (0x80+b) & 0x0F;
		Lcd4_Cmd(z);
		Lcd4_Cmd(y);
	else if(a == 2)
		temp = 0xC0 + b;
		z = temp>>4;
		y = (0xC0+b) & 0x0F;
		Lcd4_Cmd(z);
		Lcd4_Cmd(y);
void Lcd4_Init()
Lcd4_Port(0x00);
   __delay_ms(20);
  Lcd4_Cmd(0x03);
	__delay_ms(5);
  Lcd4_Cmd(0x03);
	__delay_ms(11);
  Lcd4_Cmd(0x03);
  Lcd4_Cmd(0x02);
	Lcd4_Cmd(0x02);
  Lcd4_Cmd(0x08);
	Lcd4_Cmd(0x00);
	Lcd4_Cmd(0x0C);
  Lcd4_Cmd(0x00);
  Lcd4_Cmd(0x06);
void Lcd4_Write_Char(char a)
   char temp,y;
   temp = a&0x0F;
   y = a&0xF0;
   Lcd4_Port(y>>4);             //Data transfer
	 EN = 1;
	 __delay_ms(5);
	 EN = 0;
	 Lcd4_Port(temp);
	 EN = 1;
	 __delay_ms(5);
	 EN = 0;
void Lcd4_Write_String(char *a)
	int i;
	 Lcd4_Write_Char(a[i]);
void Lcd4_Shift_Right()
	Lcd4_Cmd(0x01);
	Lcd4_Cmd(0x0C);
void Lcd4_Shift_Left()
	Lcd4_Cmd(0x01);
	Lcd4_Cmd(0x08);
//End LCD 4 Bit Interfacing Functions
first of all as you named to the files is wrong it doesn't affect on your programs but main.h file that is header file should contain all declaration part that is variable declaration and function. and main.c file should contain all function and same in case of lcd.
ok. where you have define __delay_ms() function. is it from library?
and
compiler this give warning means you have used _delay instead of _delay_ms().
plz check this one.
post you full code in zip.
I also faced this same problem .. There was problem in compiler I think so..
check weather it is working or not delay using for loop..
Hi embpic,
i solve it by replace the __delay_ms(1000) into __delay(1000)
Thanks
