chaitanya.531
Member level 1
i want to write output into a file in hard disk
plz heelp meee
plz heelp meee
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY key_exp IS
PORT
clr : IN STD_LOGIC;
clk : IN STD_LOGIC;
key_in : IN STD_LOGIC;
ukey : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
skey_0 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_1 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_2 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_3 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_4 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_5 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_6 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_7 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_8 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_9 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_10: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_11: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_12: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_13: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_14: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_15: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_16: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_17: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_18: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_19: out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_20 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_21 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_22 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_23 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_24 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
skey_25 : out STD_LOGIC_VECTOR (31 DOWNTO 0);
key_rdy : OUT STD_LOGIC
END key_exp;
architecture Behavior of key_exp is
signal i_cnt : std_logic_vector(4 downto 0);
signal j_cnt : std_logic_vector (1 downto 0);
signal k_cnt : std_logic_vector (6 downto 0);
signal a_tmp1:std_logic_vector (31 downto 0);
-- A registers
signal a_tmp2 : std_logic_vector (31 downto 0);
signal a_reg : std_logic_vector (31 downto 0);
-- B registers
signal b_tmp1 : std_logic_vector (31 downto 0);
signal b_tmp2 : std_logic_vector (31 downto 0);
signal b_reg : std_logic_vector (31 downto 0);
signal ab_tmp : std_logic_vector(31 downto 0);
TYPE S_ARRAY IS ARRAY (0 TO 25) OF STD_LOGIC_VECTOR (31 DOWNTO 0);
TYPE L_ARRAY IS ARRAY (0 TO 3) OF STD_LOGIC_VECTOR (31 DOWNTO 0);
TYPE StateType IS (ST_IDLE, ST_KEY_IN, ST_KEY_EXP, ST_READY);
SIGNAL state : StateType;
signal s_arr_tmp: S_ARRAY;
signal l_arr : L_ARRAY;
signal keyrdy :std_logic;
type rom is array (0 to 25) of std_logic_vector (31 downto 0);
signal s_key_tmp : rom;
begin
a_tmp1 <= s_arr_tmp(conv_integer(i_cnt)) + a_reg + b_reg;
-- LEFT ROTATE BY 3
a_tmp2<=a_tmp1(28 DOWNTO 0) & a_tmp1(31 DOWNTO 29);
ab_tmp<=a_tmp2 + b_reg;
b_tmp1<=l_arr(conv_integer(j_cnt)) + ab_tmp;
WITH ab_tmp(4 DOWNTO 0) SELECT
b_tmp2<=
b_tmp1(30 DOWNTO 0) & b_tmp1(31) WHEN "00001",
b_tmp1(29 DOWNTO 0) & b_tmp1(31 DOWNTO 30) WHEN "00010",
b_tmp1(28 DOWNTO 0) & b_tmp1(31 DOWNTO 29) WHEN "00011",
b_tmp1(27 DOWNTO 0) & b_tmp1(31 DOWNTO 28) WHEN "00100",
b_tmp1(26 DOWNTO 0) & b_tmp1(31 DOWNTO 27) WHEN "00101",
b_tmp1(25 DOWNTO 0) & b_tmp1(31 DOWNTO 26) WHEN "00110",
b_tmp1(24 DOWNTO 0) & b_tmp1(31 DOWNTO 25) WHEN "00111",
b_tmp1(23 DOWNTO 0) & b_tmp1(31 DOWNTO 24) WHEN "01000",
b_tmp1(22 DOWNTO 0) & b_tmp1(31 DOWNTO 23) WHEN "01001",
b_tmp1(21 DOWNTO 0) & b_tmp1(31 DOWNTO 22) WHEN "01010",
b_tmp1(20 DOWNTO 0) & b_tmp1(31 DOWNTO 21) WHEN "01011",
b_tmp1(19 DOWNTO 0) & b_tmp1(31 DOWNTO 20) WHEN "01100",
b_tmp1(18 DOWNTO 0) & b_tmp1(31 DOWNTO 19) WHEN "01101",
b_tmp1(17 DOWNTO 0) & b_tmp1(31 DOWNTO 18) WHEN "01110",
b_tmp1(16 DOWNTO 0) & b_tmp1(31 DOWNTO 17) WHEN "01111",
b_tmp1(15 DOWNTO 0) & b_tmp1(31 DOWNTO 16) WHEN "10000",
b_tmp1(14 DOWNTO 0) & b_tmp1(31 DOWNTO 15) WHEN "10001",
b_tmp1(13 DOWNTO 0) & b_tmp1(31 DOWNTO 14) WHEN "10010",
b_tmp1(12 DOWNTO 0) & b_tmp1(31 DOWNTO 13) WHEN "10011",
b_tmp1(11 DOWNTO 0) & b_tmp1(31 DOWNTO 12) WHEN "10100",
b_tmp1(10 DOWNTO 0) & b_tmp1(31 DOWNTO 11) WHEN "10101",
b_tmp1(9 DOWNTO 0) & b_tmp1(31 DOWNTO 10) WHEN "10110",
b_tmp1(8 DOWNTO 0) & b_tmp1(31 DOWNTO 9) WHEN "10111",
b_tmp1(7 DOWNTO 0) & b_tmp1(31 DOWNTO 8) WHEN "11000",
b_tmp1(6 DOWNTO 0) & b_tmp1(31 DOWNTO 7) WHEN "11001",
b_tmp1(5 DOWNTO 0) & b_tmp1(31 DOWNTO 6) WHEN "11010",
b_tmp1(4 DOWNTO 0) & b_tmp1(31 DOWNTO 5) WHEN "11011",
b_tmp1(3 DOWNTO 0) & b_tmp1(31 DOWNTO 4) WHEN "11100",
b_tmp1(2 DOWNTO 0) & b_tmp1(31 DOWNTO 3) WHEN "11101",
b_tmp1(1 DOWNTO 0) & b_tmp1(31 DOWNTO 2) WHEN "11110",
b_tmp1(0) & b_tmp1(31 DOWNTO 1) WHEN "11111",
b_tmp1 WHEN OTHERS;
-- STATE MACHINE
PROCESS(clr, clk)
BEGIN
IF(clr='0') THEN
state<=ST_IDLE;
ELSIF(clk'EVENT AND clk='1') THEN
CASE state IS
WHEN ST_IDLE =>
IF(key_in='1') THEN state<=ST_KEY_IN; keyrdy <= '0' ; END IF;
WHEN ST_KEY_IN=>
state<=ST_KEY_EXP;
keyrdy <= '0';
WHEN ST_KEY_EXP=>
IF(k_cnt="1001101") THEN
state<=ST_READY;
END IF;
WHEN ST_READY =>
keyrdy <='1';
END CASE;
END IF;
END PROCESS;
-- A REGISTER
PROCESS(clr, clk) BEGIN
IF(clr='0') THEN
a_reg <= (others => '0');
IF(state=ST_KEY_EXP) THEN a_reg<=a_tmp2;
END IF;
END IF;
END PROCESS;
-- B register
IF(clr='0') THEN
b_reg <= (others => '0');
IF(state=ST_KEY_EXP) THEN b_reg<=b_tmp2;
END IF;
END IF;
END PROCESS;
-- MOD 26 COUNTER
PROCESS(clr, clk)
BEGIN
IF(clr='0') THEN i_cnt<="00000";
IF(i_cnt="11001") THEN i_cnt<="00000";
ELSE i_cnt<=i_cnt+1;
END IF;
END IF;
END IF;
END PROCESS;
-- MOD 4 COUNTER
PROCESS(clr, clk)
BEGIN
IF(clr='0') THEN j_cnt<="00";
IF(j_cnt="11") THEN j_cnt<="00";
ELSE j_cnt<=j_cnt+1;
END IF;
END IF;
END IF;
END PROCESS;
process (clr,clk) --counter
begin
if(clr='0') then k_cnt<="0000000";
elsif(clk'EVENT AND clk='1') THEN
IF(state=ST_KEY_EXP)THEN
IF(k_cnt="1001101") then k_cnt<="0000000";
ELSE k_cnt<=k_cnt+1;
end if;
end if;
end if;
end process;
PROCESS(clr, clk)
BEGIN
IF(clr='0') THEN -- After system reset, S array is initialized with P and Q
s_arr_tmp(0) <= x"b7e15163";
s_arr_tmp(1) <= x"5618cb1c";
s_arr_tmp(2) <= x"f45044d5";
s_arr_tmp(3) <= x"9287be8e";
s_arr_tmp(4) <= x"30bf3847";
s_arr_tmp(5) <= x"cef6b200";
s_arr_tmp(6) <= x"6d2e2bb9";
s_arr_tmp(7) <= x"0b65a572";
s_arr_tmp(8) <= x"a99d1f2b";
s_arr_tmp(9) <= x"47d498e4";
s_arr_tmp(10)<= x"e60c129d";
s_arr_tmp(11)<= x"84438c56";
s_arr_tmp(12)<= x"227b060f";
s_arr_tmp(13)<= x"c0b27fc8";
s_arr_tmp(14)<= x"5ee9f981";
s_arr_tmp(15)<= x"fd21733a";
s_arr_tmp(16)<= x"9b58ecf3";
s_arr_tmp(17)<= x"399066ac";
s_arr_tmp(18)<= x"d7c7e065";
s_arr_tmp(19)<= x"75ff5a1e";
s_arr_tmp(20)<= x"1436d3d7";
s_arr_tmp(21)<= x"b26e4d90";
s_arr_tmp(22)<= x"50a5c749";
s_arr_tmp(23)<= x"eedd4102";
s_arr_tmp(24)<= x"8d14babb";
s_arr_tmp(25)<= x"2b4c3474";
IF(state=ST_KEY_EXP) THEN s_arr_tmp(conv_integer(i_cnt)) <= a_tmp2;
END IF;
END IF;
-- end if;
END PROCESS;
s_key_tmp(0) <= s_arr_tmp(0);
s_key_tmp(1) <= s_arr_tmp(1);
s_key_tmp(2) <= s_arr_tmp(2);
s_key_tmp(3) <= s_arr_tmp(3);
s_key_tmp(4) <= s_arr_tmp(4);
s_key_tmp(5) <= s_arr_tmp(5);
s_key_tmp(6) <= s_arr_tmp(6);
s_key_tmp(7) <= s_arr_tmp(7);
s_key_tmp(8) <= s_arr_tmp(8);
s_key_tmp(9) <= s_arr_tmp(9);
s_key_tmp(10) <= s_arr_tmp(10);
s_key_tmp(11) <= s_arr_tmp(11);
s_key_tmp(12) <= s_arr_tmp(12);
s_key_tmp(13) <= s_arr_tmp(13);
s_key_tmp(14) <= s_arr_tmp(14);
s_key_tmp(15) <= s_arr_tmp(15);
s_key_tmp(16) <= s_arr_tmp(16);
s_key_tmp(17) <= s_arr_tmp(17);
s_key_tmp(18) <= s_arr_tmp(18);
s_key_tmp(19) <= s_arr_tmp(19);
s_key_tmp(20) <= s_arr_tmp(20);
s_key_tmp(21) <= s_arr_tmp(21);
s_key_tmp(22) <= s_arr_tmp(22);
s_key_tmp(23) <= s_arr_tmp(23);
s_key_tmp(24) <= s_arr_tmp(24);
s_key_tmp(25) <= s_arr_tmp(25);
PROCESS(clr, clk)
BEGIN
IF(clr='0') THEN
l_arr(0)<="00000000000000000000000000000000";
l_arr(1)<="00000000000000000000000000000000";
l_arr(2)<="00000000000000000000000000000000";
l_arr(3)<="00000000000000000000000000000000";
IF(state=ST_KEY_IN) THEN
l_arr(0)<=ukey(31 DOWNTO 0);
l_arr(1)<=ukey(63 DOWNTO 32);
l_arr(2)<=ukey(95 DOWNTO 64);
l_arr(3)<=ukey(127 DOWNTO 96);
ELSIF(state=ST_KEY_EXP) THEN
l_arr(conv_integer(j_cnt))<=b_tmp2;
END IF;
END IF;
end process;
PROCESS (keyrdy)
BEGIN
if ( rising_edge(keyrdy)) and keyrdy='1' then
skey_0 <= s_key_tmp(0);
skey_1 <= s_key_tmp(1);
skey_2 <= s_key_tmp(2);
skey_3 <= s_key_tmp(3);
skey_4 <= s_key_tmp(4);
skey_5 <= s_key_tmp(5);
skey_6 <= s_key_tmp(6);
skey_7 <= s_key_tmp(7);
skey_8 <= s_key_tmp(8);
skey_9 <= s_key_tmp(9);
skey_10 <= s_key_tmp(10);
skey_11 <= s_key_tmp(11);
skey_12 <= s_key_tmp(12);
skey_13 <= s_key_tmp(13);
skey_14 <= s_key_tmp(14);
skey_15 <= s_key_tmp(15);
skey_16 <= s_key_tmp(16);
skey_17 <= s_key_tmp(17);
skey_18 <= s_key_tmp(18);
skey_19 <= s_key_tmp(19);
skey_20 <= s_key_tmp(20);
skey_21 <= s_key_tmp(21);
skey_22 <= s_key_tmp(22);
skey_23 <= s_key_tmp(23);
skey_24 <= s_key_tmp(24);
skey_25 <= s_key_tmp(25);
end if;
end process;
key_rdy <=keyrdy;
end Behavior;
ERROR:HDLParsers:164 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 89. parse error, unexpected TOKFILE
ERROR:HDLParsers:3312 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 147. Undefined symbol 'kfp'.
ERROR:HDLParsers:1209 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 147. kfp: Undefined symbol (last report in this block)
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 147. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 149. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:164 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 150. parse error, unexpected SEMICOLON
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 151. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 153. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 155. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 157. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 159. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 161. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:164 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 162. parse error, unexpected SEMICOLON
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 163. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 165. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 167. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 169. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 171. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 173. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:164 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 174. parse error, unexpected SEMICOLON
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 175. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 177. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 179. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 181. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 183. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 185. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 187. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 189. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 191. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 193. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 195. Formal parameter L of procedure writeline must be associated with an actual value.
ERROR:HDLParsers:3326 - "C:/Xilinx/rc5soc/rc5soc/testkeyexp.vhd" Line 197. Formal parameter L of procedure writeline must be associated with an actual value.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
use STD.TEXTIO.all;
use IEEE.STD_LOGIC_TEXTIO.all;
ENTITY testkeyexp_vhd IS
END testkeyexp_vhd;
ARCHITECTURE behavior OF testkeyexp_vhd IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT key_exp
generic (
outfile : string := "C:\Xilinx\rc5soc\rc5soc\rc5_encrypt_tb.key"
PORT(
clr : IN std_logic;
clk : IN std_logic;
key_in : IN std_logic;
ukey : IN std_logic_vector(127 downto 0);
skey_0 : OUT std_logic_vector(31 downto 0);
skey_1 : OUT std_logic_vector(31 downto 0);
skey_2 : OUT std_logic_vector(31 downto 0);
skey_3 : OUT std_logic_vector(31 downto 0);
skey_4 : OUT std_logic_vector(31 downto 0);
skey_5 : OUT std_logic_vector(31 downto 0);
skey_6 : OUT std_logic_vector(31 downto 0);
skey_7 : OUT std_logic_vector(31 downto 0);
skey_8 : OUT std_logic_vector(31 downto 0);
skey_9 : OUT std_logic_vector(31 downto 0);
skey_10 : OUT std_logic_vector(31 downto 0);
skey_11 : OUT std_logic_vector(31 downto 0);
skey_12 : OUT std_logic_vector(31 downto 0);
skey_13 : OUT std_logic_vector(31 downto 0);
skey_14 : OUT std_logic_vector(31 downto 0);
skey_15 : OUT std_logic_vector(31 downto 0);
skey_16 : OUT std_logic_vector(31 downto 0);
skey_17 : OUT std_logic_vector(31 downto 0);
skey_18 : OUT std_logic_vector(31 downto 0);
skey_19 : OUT std_logic_vector(31 downto 0);
skey_20 : OUT std_logic_vector(31 downto 0);
skey_21 : OUT std_logic_vector(31 downto 0);
skey_22 : OUT std_logic_vector(31 downto 0);
skey_23 : OUT std_logic_vector(31 downto 0);
skey_24 : OUT std_logic_vector(31 downto 0);
skey_25 : OUT std_logic_vector(31 downto 0);
key_rdy : OUT std_logic
END COMPONENT;
--Inputs
SIGNAL clr : std_logic := '0';
SIGNAL clk : std_logic := '0';
SIGNAL key_in : std_logic := '0';
SIGNAL ukey : std_logic_vector(127 downto 0) := (others=>'0');
--Outputs
SIGNAL skey_0 : std_logic_vector(31 downto 0);
SIGNAL skey_1 : std_logic_vector(31 downto 0);
SIGNAL skey_2 : std_logic_vector(31 downto 0);
SIGNAL skey_3 : std_logic_vector(31 downto 0);
SIGNAL skey_4 : std_logic_vector(31 downto 0);
SIGNAL skey_5 : std_logic_vector(31 downto 0);
SIGNAL skey_6 : std_logic_vector(31 downto 0);
SIGNAL skey_7 : std_logic_vector(31 downto 0);
SIGNAL skey_8 : std_logic_vector(31 downto 0);
SIGNAL skey_9 : std_logic_vector(31 downto 0);
SIGNAL skey_10 : std_logic_vector(31 downto 0);
SIGNAL skey_11 : std_logic_vector(31 downto 0);
SIGNAL skey_12 : std_logic_vector(31 downto 0);
SIGNAL skey_13 : std_logic_vector(31 downto 0);
SIGNAL skey_14 : std_logic_vector(31 downto 0);
SIGNAL skey_15 : std_logic_vector(31 downto 0);
SIGNAL skey_16 : std_logic_vector(31 downto 0);
SIGNAL skey_17 : std_logic_vector(31 downto 0);
SIGNAL skey_18 : std_logic_vector(31 downto 0);
SIGNAL skey_19 : std_logic_vector(31 downto 0);
SIGNAL skey_20 : std_logic_vector(31 downto 0);
SIGNAL skey_21 : std_logic_vector(31 downto 0);
SIGNAL skey_22 : std_logic_vector(31 downto 0);
SIGNAL skey_23 : std_logic_vector(31 downto 0);
SIGNAL skey_24 : std_logic_vector(31 downto 0);
SIGNAL skey_25 : std_logic_vector(31 downto 0);
SIGNAL key_rdy : std_logic;
CONSTANT clk_period : time := 10 ns;
BEGIN
file kfp : text open write_mode is keyfile;
-- Instantiate the Unit Under Test (UUT)
uut: key_exp PORT MAP(
clr => clr,
clk => clk,
key_in => key_in,
ukey => ukey,
skey_0 => skey_0,
skey_1 => skey_1,
skey_2 => skey_2,
skey_3 => skey_3,
skey_4 => skey_4,
skey_5 => skey_5,
skey_6 => skey_6,
skey_7 => skey_7,
skey_8 => skey_8,
skey_9 => skey_9,
skey_10 => skey_10,
skey_11 => skey_11,
skey_12 => skey_12,
skey_13 => skey_13,
skey_14 => skey_14,
skey_15 => skey_15,
skey_16 => skey_16,
skey_17 => skey_17,
skey_18 => skey_18,
skey_19 => skey_19,
skey_20 => skey_20,
skey_21 => skey_21,
skey_22 => skey_22,
skey_23 => skey_23,
skey_24 => skey_24,
skey_25 => skey_25,
key_rdy => key_rdy
clk_process :PROCESS
begin
clk <= '0';
wait for clk_period/2; --for 5 ns signal is '0'.
clk <= '1';
wait for clk_period/2; --for next 5 ns signal is '1'.
end process;
tb : PROCESS
BEGIN
key_in <= '0';
-- Wait 100 ns for global reset to finish
wait for 100 ns;
key_in <= '1';
clr <= '1';
ukey <= x"12345678901234567890123456789012";
-- Place stimulus here
wait; -- will wait forever
END PROCESS;
text :PROCESS
variable L : line;
BEGIN
wait until key_rdy ='1';
for i in 0 to 25 loop
write(L,skey_0); writeline(kfp,L);
wait for 1ns;
write(L,skey_1); writeline(kfp,L);
wait for 1ns;;
write(L,skey_2); writeline(kfp,L);
wait for 1ns;
write(L,skey_3); writeline(kfp,L);
wait for 1ns;
write(L,skey_4); writeline(kfp,L);
wait for 1ns;
write(L,skey_5); writeline(kfp,L);
wait for 1ns;
write(L,skey_6); writeline(kfp,L);
wait for 1ns;
write(L,skey_7); writeline(kfp,L);
wait for 1ns;;
write(L,skey_8); writeline(kfp,L);
wait for 1ns;
write(L,skey_9); writeline(kfp,L);
wait for 1ns;
write(L,skey_10); writeline(kfp,L);
wait for 1ns;
write(L,skey_11); writeline(kfp,L);
wait for 1ns;
write(L,skey_12); writeline(kfp,L);
wait for 1ns;
write(L,skey_13); writeline(kfp,L);
wait for 1ns;;
write(L,skey_14); writeline(kfp,L);
wait for 1ns;
write(L,skey_15); writeline(kfp,L);
wait for 1ns;
write(L,skey_16); writeline(kfp,L);
wait for 1ns;
write(L,skey_17); writeline(kfp,L);
wait for 1ns;
write(L,skey_18); writeline(kfp,L);
wait for 1ns;
write(L,skey_19); writeline(kfp,L);
wait for 1ns;
write(L,skey_20); writeline(kfp,L);
wait for 1ns;
write(L,skey_21); writeline(kfp,L);
wait for 1ns;
write(L,skey_22); writeline(kfp,L);
wait for 1ns;
write(L,skey_23); writeline(kfp,L);
wait for 1ns;
write(L,skey_24); writeline(kfp,L);
wait for 1ns;
write(L,skey_25); writeline(kfp,L);
end loop ;
END PROCESS;
END;
Please be clearer with your posts.
If you have errors, Post what the errors are, along with the code causing the problem.
