help in ethernet controller code
asrock
Junior Member level 3
hello every one
i would ask you in an example embedded in MikroC that illustrates how to use PIC to control through ETHERNET
i executed the example and it works successfully , here it's
 * Project Name:
     enc28j60Demo (Ethernet Library demo for ENC28J60 mcu)
 * Target Platform:
     PIC
 * Copyright:
     (c) MikroElektronika, 2005-2010
 * Revision History:
     20060810:
       - Initial release. Author: Bruno Gavand.
 * V1.0 : first release
 * V1.1 : bad MIME type for / path request, changed to HTML instead of SCRIPT (thanks Srdjan !)
 * description  :
 *      this code shows how to use the Spi_Ethernet mini library :
 *              the board will reply to ARP & ICMP echo requests
 *              the board will reply to UDP requests on any port :
 *                      returns the request in upper char with a header made of remote host IP & port number
 *              the board will reply to HTTP requests on port 80, GET method with pathnames :
 *                      /               will return the HTML main page
 *                      /s              will return board status as text string
 *                      /t0 ... /t7     will toggle RD0 to RD7 bit and return HTML main page
 *                      all other requests return also HTML main page
 * target devices :
 *      any PIC with integrated SPI and more than 4 Kb ROM memory
 *      32 to 40 MHz clock is recommended to get from 8 to 10 Mhz SPI clock,
 *      otherwise PIC should be clocked by ENC clock output due to ENC silicon bug in SPI hardware
 *      if you try lower PIC clock speed, don't be surprised if the board hang or miss some requests !
 * EP settings :
 *      RA2 & RA3 pots jumper : closed
 *      PORTA : pull-down  (place jumper J1 to lower position)  (board specific)
 *      PORTB : pull-down  (place jumper J2 to lower position)  (board specific)
 *      PORTC : pull-up    (place jumper J3 to upper position)  (board specific)
 *      BUTTONS : pull-up  (place jumper J17 to upper position)  (board specific)
 *      RC0 : !RESET    to ENC reset input pin
 *      RC1 : !CS       to ENC chip select input pin
 *      the ENC28J60 SPI bus CLK, SO, SI must be connected to the corresponding SPI pins of the PIC
 *      the INT and WOL signals from the ENC are not used
 * Test configuration:
     MCU:             PIC16F887
                      http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
     Dev.Board:       EasyPIC6
                      http://www.mikroe.com/eng/products/view/297/easypic6-development-system/
     Oscillator:      HS, 08.000MHz
     Ext. Modules:    ac:Serial_Ethernet_Board
     SW:              mikroC PRO for PIC
                      http://www.mikroe.com/eng/products/view/7/mikroc-pro-for-pic/
 * NOTES:
     - Make sure that you use right compiler version with this project (v6.2 and older).
       Spi ethernet library routines are renamed from (v6.0)ENC28j60... to (v6.2)Spi_Ethernet...
     - Since the ENC28J60 doesn't support auto-negotiation, full-duplex mode is
       not compatible with most switches/routers.  If a dedicated network is used
       where the duplex of the remote node can be manually configured, you may
       change this configuration.  Otherwise, half duplex should always be used.
     - External power supply should be used due to Serial Ethernet Board power consumption.
#include  "__EthEnc28j60.h"
// duplex config flags
#define Spi_Ethernet_HALFDUPLEX     0x00  // half duplex
#define Spi_Ethernet_FULLDUPLEX     0x01  // full duplex
// mE ehternet NIC pinout
sfr sbit SPI_Ethernet_Rst at RC0_bit;
sfr sbit SPI_Ethernet_CS  at RC1_bit;
sfr sbit SPI_Ethernet_Rst_Direction at TRISC0_bit;
sfr sbit SPI_Ethernet_CS_Direction  at TRISC1_bit;
// end ethernet NIC definitions
 * ROM constant strings
const unsigned char httpHeader[] = "HTTP/1.1 200 OK\nContent-type: " ;  // HTTP header
const unsigned char httpMimeTypeHTML[] = "text/html\n\n" ;              // HTML MIME type
const unsigned char httpMimeTypeScript[] = "text/plain\n\n" ;           // TEXT MIME type
unsigned char httpMethod[] = "GET /";
 * web page, splited into 2 parts :
 * when coming short of ROM, fragmented data is handled more efficiently by linker
 * this HTML page calls the boards to get its status, and builds itself with javascript
const   char    *indexPage =                   // Change the IP address of the page to be refreshed
"<meta http-equiv=\"refresh\" content=\"3;url=http://192.168.20.60\">\
<HTML><HEAD></HEAD><BODY>\
<h1>ENC28J60 Ethernet Control</h1>\
<a href=/>Reload</a>\
<script src=/s></script>\
<table><tr><td valign=top><table border=1 style=\"font-size:20px ;font-family: terminal ;\">\
<tr><th colspan=2>ADC</th></tr>\
<tr><td>AN2</td><td><script>document.write(AN2)</script></td></tr>\
<tr><td>AN3</td><td><script>document.write(AN3)</script></td></tr>\
</table></td><td><table border=1 style=\"font-size:20px ;font-family: terminal ;\">\
<tr><th colspan=2>PORTB</th></tr>\
<script>\
var str,i;\
str=\"\";\
for(i=0;i<8;i++)\
{str+=\"<tr><td bgcolor=pink>BUTTON #\"+i+\"</td>\";\
if(PORTB&(1<<i)){str+=\"<td bgcolor=red>ON\";}\
else {str+=\"<td bgcolor=#cccccc>OFF\";}\
str+=\"</td></tr>\";}\
document.write(str) ;\
</script>\
const   char    *indexPage2 =  "</table></td><td>\
<tr><th colspan=3>PORTD</th></tr>\
<script>\
var str,i;\
str=\"\";\
for(i=0;i<8;i++)\
{str+=\"<tr><td bgcolor=yellow>LED #\"+i+\"</td>\";\
if(PORTD&(1<<i)){str+=\"<td bgcolor=red>ON\";}\
str+=\"</td><td><a href=/t\"+i+\">Toggle</a></td></tr>\";}\
</script>\
</table></td></tr></table>\
This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>\
 * RAM variables
unsigned char   myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f} ;   // my MAC address
unsigned char   myIpAddr[4]  = {192, 168, 20, 60} ;                     // my IP address
unsigned char   getRequest[15] ;                                        // HTTP request buffer
unsigned char   dyna[30] ;                                              // buffer for dynamic response
unsigned long   httpCounter = 0 ;                                       // counter of HTTP requests
 * functions
 * put the constant string pointed to by s to the ENC transmit buffer.
/*unsigned int    putConstString(const char *s)
        unsigned int ctr = 0 ;
        while(*s)
                Spi_Ethernet_putByte(*s++) ;
                ctr++ ;
        return(ctr) ;
 * it will be much faster to use library Spi_Ethernet_putConstString routine
 * instead of putConstString routine above. However, the code will be a little
 * bit bigger. User should choose between size and speed and pick the implementation that
 * suites him best. If you choose to go with the putConstString definition above
 * the #define line below should be commented out.
#define putConstString  SPI_Ethernet_putConstString
 * put the string pointed to by s to the ENC transmit buffer
/*unsigned int    putString(char *s)
        while(*s)
                ctr++ ;
        return(ctr) ;
 * it will be much faster to use library Spi_Ethernet_putString routine
 * instead of putString routine above. However, the code will be a little
 * suites him best. If you choose to go with the putString definition above
#define putString  SPI_Ethernet_putString
 * this function is called by the library
 * the user accesses to the HTTP request by successive calls to Spi_Ethernet_getByte()
 * the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte()
 * the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
 * if you don't need to reply to HTTP requests,
 * just define this function with a return(0) as single statement
unsigned int  SPI_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength, TEthPktFlags *flags)
        unsigned int    len = 0 ;                   // my reply length
        unsigned int    i ;                         // general purpose integer
        // should we close tcp socket after response is sent?
        // library closes tcp socket by default if canClose flag is not reset here
        // flags->canClose = 0; // 0 - do not close socket
                          // otherwise - close socket
        if(localPort != 80)                         // I listen only to web request on port 80
                return(0) ;
        // get 10 first bytes only of the request, the rest does not matter here
        for(i = 0 ; i < 10 ; i++)
                getRequest[i] = SPI_Ethernet_getByte() ;
        getRequest[i] = 0 ;
        if(memcmp(getRequest, httpMethod, 5))       // only GET method is supported here
                return(0) ;
        httpCounter++ ;                             // one more request done
        if(getRequest[5] == 's')                    // if request path name starts with s, store dynamic data in transmit buffer
                // the text string replied by this request can be interpreted as javascript statements
                // by browsers
                len = putConstString(httpHeader) ;              // HTTP header
                len += putConstString(httpMimeTypeScript) ;     // with text MIME type
                // add AN2 value to reply
                IntToStr(ADC_Read(2), dyna) ;
                len += putConstString("var AN2=") ;
                len += putString(dyna) ;
                len += putConstString(";") ;
                // add AN3 value to reply
                IntToStr(ADC_Read(3), dyna) ;
                len += putConstString("var AN3=") ;
                // add PORTB value (buttons) to reply
                len += putConstString("var PORTB=") ;
                IntToStr(PORTB, dyna) ;
                // add PORTD value (LEDs) to reply
                len += putConstString("var PORTD=") ;
                IntToStr(PORTD, dyna) ;
                // add HTTP requests counter to reply
                IntToStr(httpCounter, dyna) ;
                len += putConstString("var REQ=") ;
        else if(getRequest[5] == 't')                           // if request path name starts with t, toggle PORTD (LED) bit number that comes after
                unsigned char   bitMask = 0 ;                   // for bit mask
                if(isdigit(getRequest[6]))                      // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
                        bitMask = getRequest[6] - '0' ;         // convert ASCII to integer
                        bitMask = 1 << bitMask ;                // create bit mask
                        PORTD ^= bitMask ;                      // toggle PORTD with xor operator
        if(len == 0)                                            // what do to by default
                len += putConstString(httpMimeTypeHTML) ;       // with HTML MIME type
                len += putConstString(indexPage) ;              // HTML page first part
                len += putConstString(indexPage2) ;             // HTML page second part
        return(len) ;                                           // return to the library with the number of bytes to transmit
 * the user accesses to the UDP request by successive calls to Spi_Ethernet_getByte()
 * the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
 * if you don't need to reply to UDP requests,
unsigned int  SPI_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength, TEthPktFlags *flags)
        unsigned int    len ;                           // my reply length
        // reply is made of the remote host IP address in human readable format
        ByteToStr(remoteHost[0], dyna) ;                // first IP address byte
        dyna[3] = '.' ;
        ByteToStr(remoteHost[1], dyna + 4) ;            // second
        dyna[7] = '.' ;
        ByteToStr(remoteHost[2], dyna + 8) ;            // third
        dyna[11] = '.' ;
        ByteToStr(remoteHost[3], dyna + 12) ;           // fourth
        dyna[15] = ':' ;                                // add separator
        // then remote host port number
        WordToStr(remotePort, dyna + 16) ;
        dyna[21] = '[' ;
        WordToStr(destPort, dyna + 22) ;
        dyna[27] = ']' ;
        dyna[28] = 0 ;
        // the total length of the request is the length of the dynamic string plus the text of the request
        len = 28 + reqLength;
        // puts the dynamic string into the transmit buffer
        SPI_Ethernet_putBytes(dyna, 28) ;
        // then puts the request string converted into upper char into the transmit buffer
        while(reqLength--)
                SPI_Ethernet_putByte(toupper(SPI_Ethernet_getByte())) ;
        return(len) ;           // back to the library with the length of the UDP reply
 * main entry
void    main()
        ANSEL = 0x0C ;          // AN2 and AN3 convertors will be used
        C1ON_bit = 0;           // Disable comparators
        C2ON_bit = 0;
        PORTA = 0 ;
        TRISA = 0xff ;          // set PORTA as input for ADC
/       ANSELH = 0;             // Configure other AN pins as digital I/O
        PORTB = 0 ;
        TRISB = 0xff ;          // set PORTB as input for buttons
        PORTD = 0 ;
        TRISD = 0 ;             // set PORTD as output
         * starts ENC28J60 with :
         * reset bit on RC0
         * CS bit on RC1
         * my MAC & IP address
         * full duplex
        SPI1_Init();
        SPI_Ethernet_Init(myMacAddr, myIpAddr, Spi_Ethernet_FULLDUPLEX) ;
        while(1)                            // do forever
                 * if necessary, test the return value to get error code
                SPI_Ethernet_doPacket() ;   // process incoming Ethernet packets
                 * add your stuff here if needed
                 * Spi_Ethernet_doPacket() must be called as often as possible
                 * otherwise packets could be lost
but i need to add to code in how to make a text field in page, and send text to LCD connected to PIC
i'm not bad in HTML , but how to bring the text from text field to variable to view on LCD
any one can help me plz :)
Hello, my project name is Serial Ethernet Board- communication between PC and MCU trough Ethernet and ENC28J60 but I don't know how to start it. I have to write code in MikroC so if anyone can help me or send mi some code it would be great
Hi stupi, im also stuck as u are, have u been able to find your way out. Help please
I used code from the library, but it's not finished, yet. If I figured out how to do this, I'll send you that!
