[SOLVED] help in debugging fsm functionality in vhdl
rakeshk.r
Member level 2
Member level 2
HI , I have 3 states, 's0' to initialize the values and 's1' to count and stay untill it reaches value 4 and move to stop state 's2' when it reaches 5. The problem here is that the entire count finishes in 1 clock edge rather i wanted each count to happen on each rising edge of clock untill it reaches value 5. How to fix this. since my other components are synchronous design. I wanted my fsm too be synchronous to clock. Below I have the design code, snippet of my testbench and output waveform of the fsm design. Thank you.
 LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
ENTITY test_hdl IS
port  ( clk : IN std_logic;
        rst : IN std_logic;
        en  : IN std_logic;
        output : OUT std_logic
END ENTITY test_hdl;
ARCHITECTURE test1 OF test_hdl IS
signal itr : unsigned  (12 downto 0);
signal en_out : std_logic;
type STATE_TYPE is (s0, s1, s2);
signal PRESENT_STATE:  STATE_TYPE;
signal NEXT_STATE: STATE_TYPE;
BEGIN
STATE_proc: process (clk)
begin
if rising_edge(clk) then
         if (rst='0') then
     	       PRESENT_STATE <= NEXT_STATE;
         else
             PRESENT_STATE <= s0;
        end if; -- rst
end if;
end process STATE_proc;
comb_proc: process(PRESENT_STATE,en,itr)
variable itr_reg : unsigned(12 downto 0);
variable reg1 : integer range 0 to 10;
begin
case PRESENT_STATE is
when s0 =>
        if en = '1' then
          NEXT_STATE <= s1;
        else
          NEXT_STATE <= s0;
        end if;
        itr_reg := (others=>'0');
        itr <= (others=>'0');
        reg1 := 0;
        en_out <= '0';
        output <= '0';
  when s1 =>
        if en='1' then
            if itr_reg < 5 then
               itr_reg := itr;
               itr <= itr_reg + 1;
               NEXT_STATE <= s1;
               output <= '1';
               en_out <= '1';
            else
               NEXT_STATE <= s2;
               output <= '0';
               en_out <= '0';
            end if;
         else
            NEXT_STATE <= s0;
            output <= '0';
         end if;
         reg1 := to_integer(itr_reg);
  when s2 =>
       if en = '1' then
         NEXT_STATE <= s2;
       else
         NEXT_STATE <= s0;
       end if;
       output <= '0';
       en_out <= '0';
end case;
end process comb_proc;
END ARCHITECTURE test1;
-- Test Bench ---
LIBRARY ieee;
LIBRARY project_lib;
ENTITY tb_test_hdl IS
END ENTITY tb_test_hdl;
ARCHITECTURE arch OF tb_test_hdl IS
-- internal signal
signal clk_tb   : std_logic := '0';
signal rst_tb   : std_logic := '1';
signal en_tb   : std_logic := '0';
signal out_tb   : std_logic;
constant clk_period : time := 10 ns;
-- component instantiation
component test_hdl
  port(
      clk   : IN     std_logic;
      rst   : IN   std_logic;
      en    : IN std_logic;
      output: OUT   std_logic
end component;
For all : test_hdl use entity project_lib.test_hdl;
BEGIN
-- instantiate the Unit Under Test
   uut:test_hdl port map(
        clk => clk_tb,
        rst => rst_tb,
        en  => en_tb,
        output => out_tb
clk_toggle:process
begin
  clk_tb <= '1';
  wait for clk_period/2;  -- for 5 ns clk is 'low'.
  clk_tb <= '0';
  wait for clk_period/2;  -- for next 5 ns clk is 'high'.
end process;
sim_tb: process
begin
  rst_tb <= '1';
  en_tb <= '0';
  wait for 10 ns;
  en_tb <= '1';
  rst_tb <= '0';
  wait for 100 ns;
  en_tb <= '0';
wait;
end process;
END ARCHITECTURE arch;
I wonder how your code compile ... There are errors in your code....where is the beginning of combo logic ??
oops sorry about that. Now I have edited the starting part of combo logic . Thanks for letting me know.
your itr signal does not increment with clock, it increments when fsm is in s1 state.
Try incrementing it in seq. logic.
You also cannt create registers with variables in an async process. Thye need to be in a clocked process.
