help,how to convart clock 12 hours formet ??
md.rokon
Junior Member level 1
  • Digital Clock AT89c2051MODI.rar
work is fine so..hours show 13:00:00, how to hours 1:00:00??
Two possible ways
1. substract 12 from hours value in BCD arithmetic
2. set the RTC to 12 hours mode (the dataseheet tells how)
you can set the 12 hrs mode by enabling the 6th bit of Hour register ( for DS 1307). then the 5th bit indicates the AM/PM( 1 for PM and 0 for AM)
how to change 12 hours ????any idea??
#include<reg52.h>
sbit DATA1 = P1^4;
sbit SCK1 = P1^5;
sbit LACH1 = P1^6;
sbit set=P1^3;
sbit up=P1^2;
sbit down=P1^1;
unsigned char hour, minute, second,c;
unsigned char ma[]={0x3F,0x6,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
unsigned char kt=0,a=0,i,k,x=0;
bit set0=1,set1=1,up1=1,up0=1,down0=1,down1=1;
sbit SCL = P3^4;
sbit SDA = P3^5;
void delay(){
unsigned char i;
for (i = 0; i < 4; i++){};
void SCL_high(){
SCL = 1;
delay();
void SCL_low(){
SCL = 0;
delay();
void I2C_Start(){
SDA = 1;
SCL = 1;
SDA = 0;
delay();
SCL = 0;
SDA = 1;
void I2C_Stop(){
SDA = 0;
SCL_high();
SDA = 1;
bit I2C_Write(unsigned char dat){
unsigned char i;
bit outbit;
for (i = 1; i <= 8; i++){
outbit=dat&0x80;
SDA = outbit;
dat = dat << 1;
SCL_high();
SCL_low();
SDA = 1;
SCL_high();
outbit = SDA;
SCL_low();
return(outbit);
unsigned char I2C_Read(bit ack)
unsigned char i, dat;
bit inbit;
dat = 0;
for(i=1;i<=8;i++)
SCL_high();
inbit = SDA;
dat = dat << 1;
dat = dat | inbit;
SCL_low();
if (ack) SDA = 0;
else SDA = 1;
SCL_high();
SCL = 0;
SDA = 1;
delay();
return(dat);
void rtc_write(unsigned char add, unsigned char dat){
I2C_Start();
I2C_Write(0xd0);
I2C_Write(add);
I2C_Write(((dat/10)<<4)|(dat%10));
I2C_Stop();
unsigned char rtc_read(unsigned char add){
unsigned char dat;
I2C_Start();
I2C_Write(0xd0);
I2C_Write(add);
I2C_Start();
I2C_Write(0xd1);
dat = I2C_Read(0);
I2C_Stop();
dat = (dat & 0x0F) + (dat>>4)*10;
return (dat);
void writeds(){
rtc_write(0x00, second);
rtc_write(0x01, minute);
rtc_write(0x02, hour);
void readds()
if(kt==0)
if(a==1)
{writeds();a=0;
second = rtc_read(0x00);
minute = rtc_read(0x01);
hour = rtc_read(0x02);
void hienthi(unsigned char x)
unsigned int i,temp;
for(i=0;i<8;i++)
temp=x;
temp=temp&0x80;
if(temp==0x80)
DATA1=1;
else
DATA1=0;
x*=2;
SCK1=0;
SCK1=1;
void quetled()
if(kt==0)
hienthi(ma[second%10]);
hienthi(ma[second/10]);
hienthi(ma[minute%10]);
hienthi(ma[minute/10]);
hienthi(ma[hour%10]);
hienthi(ma[hour/10]);
LACH1=0;
LACH1=1;
if(kt==1)
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
LACH1=0;
LACH1=1;
if(kt==2)
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
LACH1=0;
LACH1=1;
if(kt==3)
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
hienthi(0x00);
LACH1=0;
LACH1=1;
void ktphim()
set0=set1;set1=set;
if((set0==1)&&(set1==0))
kt++;
if(kt>3)kt=0;
switch(kt)
case 0:break;
case 1:
up0=up1;up1=up; a=1;
if((up0==1)&&(up1==0))
hour++;
if(hour>20)hour=0;
down0=down1;down1=down;
if((down0==1)&&(down1==0))
hour--;
if(hour==-1)
hour=23;
break;
case 2:
minute++;
if(minute>59)
minute=0;
minute--;
if(minute==-1)
minute=59;
break;
case 3:
up0=up1;up1=up;a=1;
second++;
if(second>59)
second++;
second=0;
break;
void main()
I2C_Start();
I2C_Write(0xD1);
I2C_Write(0x07);
I2C_Write(0x10);
I2C_Stop();
while(1)
ktphim();
readds();
quetled();
