Hello colleagues,
Can you suggest me which is the good PIC programmer to buy ?
It should be that can program many models ( 16F/Cxxx, 18F/Cxxx ).
Thanks
Hello colleagues,
Thanks
If you really want to buy a good programmer, I suggested to you the Microchip ICD (In Circuit Debugger). This is a debugger, and a programmer too. It's a very good equipment. I have a PICSTART+ but a friend have ICD and it's a very powerfull tool.
Hello colleagues,
Thanks
If you want to do an easy programmer, I recomend you the "PG2C" programmer, by Olimex. It's a very easy to do programmer. All that you need to know is the pic programmer pin (MCLR,VDD,PGD,PGC,PGM). It use the serial port.
I'm using the "propic2" programmer. It's a litle more complicated, but it have external power (i don't have the schematic, but if you need it, i search for it).
To use the propic2 with WinPic800 software, you must to do some configurations, i show you in the second image.
I have an usb programmer, it's a litle complicated to do and i don't prove it. If you want it, i'll upload it.
