HELP!!!!!! Fundemental frequency
yjlum
Need help here what is the fundamental period for sin[(2n-1)/3]πt???
I got it down to T=6/(2n-1) and i am confuse from here on :(
The period of a sinusoid is 2•Π that means it repeats every 2•Π. Matematically
sin(x)=sin(x+2•Π)
then considering two time values t1 and t2 we can write:
[(2n-1)/3]•Π•t2 = [(2n-1)/3]•Π•t1+2•Π
The period T is given by t2-t1. We can arbitrary set t1=0 so that T=t2, thus:
[(2n-1)/3]•Π•T = 2•Π rearranging:
T=(2•Π)/{[(2n-1)/3]•Π} ==> T=6/(2n-1)
sin(x)=sin(x+2•Π)
Thanks mate thats what i got, my qns is what is the fundemental period then??:?:
I.e how would you determine fundemental period from T=6/(2n-1) ??
There should be something wrong. Since I saw the time dependency from 't' I expect that you are speaking of an analog signal and 'n' is a parameter to be set. In this case you will have a period that is T=6/(2n-1) function of the parameter 'n' and this is also the fundamental period.
If instead you are speaking of a discrete sequence, 't' should not appear or have to be a costant, then you have to find the fundamental period as the smallest integer over which the sequence repeats.
hmm here is the whole picture..
So is the fundamental period 6?
You have a sum of periodic function, then the fundamental period is the least common multiple (lcm) among all the periods. Since the denominator is always an integer number, then the lcm is given by the numerator.
As you said it is 6.
Reactions: yjlum
    yjlum
