rezaee
Full Member level 2
I want to simulate a simple L-C circuit in HSpice but i want to use spiral inductor with TSMC0.18um cmos technology , now please tell me how i can present this inductor in HSpice? how i write the netlist??
I don't request such answer.rezaee said:@pancho_hideboo:I used HB simulator engine
Typical Design Frameworks are Cadence DFII, Mentor Falcon(IC Station) and Agilent ADS.rezaee said:what is your means from framework?
If you have model files of HSPICE syntax, it is possible.rezaee said:Now my question is how its possible for me?
So you must have an ADS model and/or netlist of your spiral inductors. If you'd post it here, perhaps somebody could help you to convert it into its HSpice counterpartrezaee said:... I have designed and simulation a PA circuit in agilent ADS with the elements of TSMC0.18um ... and spiral inductors now i want to simulate this circuit with same technology in HSpice.
Below pls. find a Spectre model for a spiral inductor from an older RF process. Don't know if it can be of help for you.rezaee said:... i want model for ... spiral inductor
Try by yourself.rezaee said:@pancho_hideboo: i dont know syntax of netlist of ADS, HSPICE , If i post the ADS designkit to you Is it possible for you to convert it to HSPICE syntax for me?
See "tsmc_rfcmos018_v5a/circuit/models/rf018.net".rezaee said:you can see the designkit here: TSMC0.18um version 5
; Translated with ADS Netlist Translator (*) 230.300 Apr 6 2003
; * TSMC RF SPICE MODEL *
; This model has been modified for RF purppose.
; PROCESS : 0.18um Mixed-Signal SALICIDE(1P6M+, 1.8V/3.3V)
; MODEL : BSIM3 ( V3.2 )
; DOC. NO.: T-018-MM-SP-001
; VERSION : 1.3
; DATE : Aug. 19, 2004
; ADS VERSION : V2003C
#ifdef RF_IND
; 3) SPIRAL INDUCTOR MODEL :
; HSPICE LEVEL 49:
; ## library files:
; The Inductors are modeled with sub-circuit 'spiral_s*_std', 'spiral_s*_sym', and 'spiral_s*_sym_ct'
; .subckt spiral_s2_std : Standard model with space=2um(fixed w=6um,9um,15um) for Inductance varies with turn(1/4turn increments) and radius
; .subckt spiral_s3_std : Standard model with space=3um(fixed w=30um) for Inductance varies with turn(1/4turn increments) and radius
; .subckt spiral_s2_sym : Symmetric model with space=2um(fixed w=9um,15um) for Inductance varies with turn(integral turn increments) and radius
; .subckt spiral_s3_sym : Symmetric model with space=3um(fixed w=30um) for Inductance varies with turn(integral turn increments) and radius
; .subckt spiral_s2_sym_ct : Symmetric model(CT) with space=2um(fixed w=9um,15um) for Inductance varies with turn(odd turn increments) and radius
; .subckt spiral_s3_sym_ct : Symmetric model(CT) with space=3um(fixed w=30um) for Inductance varies with turn(odd turn increments) and radius
; Model name turn rad (um)
; low high low high
; spiral_s2_std W=6um 0.5 5.5 30 125
; W=9um 0.5 5.5 30 125
; W=15um 0.5 5.5 30 125
; spiral_s3_std W=30um 1.5 5.5 30 125
; spiral_s2_sym W=9um 1 4 30 120
; W=15um 1 5 40 120
; spiral_s3_sym W=30um 1 5 65 150
; spiral_s2_sym_ct W=9um 1 3 30 120
; W=15um 1 5 40 120
; spiral_s3_sym_ct W=30um 1 5 65 150
[snipped]
#endif
