[SOLVED] help for a simple counter
Cyrus the Great
Member level 4
IRAN
hi.i want program my micro for counting by pushing button.i write half of my programming which can count and show the number on 7-segment.i want make it down counter by another button. please help me.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
#include <mega16.h>
char digits[16]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,
0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
unsigned char;
unsigned char p_state;
unsigned char key;
unsigned char i;
void main(void)
    DDRD = 0xFF;
    PORTD = digits[0];
    DDRC = 0x00;
    PORTC = 0xFF;
    while(1)
        if(!PINC.0)
                if(key!=p_state)
                        if(i==15)
                                i=0;
                                PORTC=digits[0];
                        else
                        i++;
                        PORTD = digits[i];
                        p_state=key;
        else
            p_state=0xFF;
papunblg
Advanced Member level 3
Kolkata India
Code C - [expand]
#include <mega16.h>
char digits[16]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
If its a seven segment display, as you have mentioned above, why you have declared and initialized an array containing 16 elements!! You want to display numbers from 0 to 9
For common cathod display use
unsigned char digits[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x67};
Cyrus the Great
Member level 4
IRAN
hi dear papunblg .I want to show 10,11,12,13,14,15, by A,B,C,D,E,F,.I want to know how can I count from 15 to 0 .I mean, I want count 1-2-3-4-5-6-7-8-9-a-b-c-d-e-f by one push button and count f-e-d-c-b-a-9-8-7-6-5-4-3-2-1 by another push button.
regard
pesarirouni
alexan_e
Administrator
Greece
Can you describe your interface?
PINC.0 has a button but I don't see any other button in your code so how do you choose to count up and down?
---------- Post added at 18:15 ---------- Previous post was at 18:01 ----------
I would expect a code like
Code C - [expand]
8
9
10
11
12
13
14
15
16
while(1)
        if(!PINC.0) // count up
            if(i==15) i=0;
            else i++;
            // add some delay here
        else
            if(!PINC.1) // count down
                if(i==0) i=15;
                else i--;
you can add the display code
Cyrus the Great
Member level 4
IRAN
dear alexan_e .as i said,i just know how count up.so as you say when i want count down i should use another pin as button.
regard
pesarirouni
alexan_e
Administrator
Greece
In my example I have used PINC.1 for a second button (or change it if you want to another pin) so what more do you need to make it work?
Cyrus the Great
Member level 4
IRAN
I do what you say,but unfortunately it doesn't work yet.I Chang my program to thise
#include <mega16.h>
#include <delay.h>
unsigned char;
unsigned char key;
unsigned char i;
void main(void)
    DDRD = 0xFF;
    PORTD = digits[0];
    DDRC = 0x00;
    PORTC = 0xFF;
    while(1)
        if(!PINC.0)
                if(key!=p_state)
                        if(i==0)
                                i=15;
                                PORTC=digits[0];
                        else
                        i++;
                        PORTD = digits[i];
                        p_state=key;
                        delay_ms(200);
        else
            p_state=0xFF;
        if(!PINC.1)
                if(key!=p_state)
                        if(i==0)
                                i=15;
                                PORTC=digits[0];
                        else
                        i--;
                        PORTD = digits[i];
                        p_state=key;
        else
            p_state=0x00;
           delay_ms(200);
and now the down counter is work.but up counter doesn't work yet.
alexan_e
Administrator
Greece
What is the point of using the key and p_state variables?
And why do you use PORTC=digits[0]?
This should work fine
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
#include <mega16.h>
#include <delay.h>
char digits[16]= {0x3F,0x06,0x5B,0x4F,0x66,0x6D,
unsigned char;
unsigned char key;
unsigned char i;
void main(void)
    DDRD = 0xFF;
    PORTD = digits[0];
    DDRC = 0x00;
    PORTC = 0xFF;
    while(1)
        if(!PINC.0)
            if(i==0)
                i=15;
            else
                i++;
            PORTD = digits[i];
            delay_ms(200);
        else
            if(!PINC.1)
                if(i==0)
                    i=15;
                else
                    i--;
                PORTD = digits[i];
                delay_ms(200);
Cyrus the Great
Member level 4
IRAN
my dear friend.i use key & p_state variables for the time that the user push the button and don't release that.by this variable when the user push the button & don't release, the counter doesn't count.and the user should push and release the button to count.
alexan_e
Administrator
Greece
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
#include <mega16.h>
#include <delay.h>
unsigned char button_down;
unsigned char key;
unsigned char i;
void main(void)
    DDRD = 0xFF;
    PORTD = digits[0];
    DDRC = 0x00;
    PORTC = 0xFF;
    while(1)
        if(!PINC.0)
        {   button_down=1;
            if(!button_down) {
                if(i==0)
                    i=15;
                else
                    i++;
            PORTD = digits[i];
            delay_ms(200);
        else
            if(!PINC.1)
            {   button_down=1;
                if(!button_down) {
                    if(i==0)
                        i=15;
                    else
                        i--;
                PORTD = digits[i];
                delay_ms(200);
            else
                button_down=0;
Cyrus the Great
Member level 4
IRAN
hi.i finally solve my problem.the answer is
#include <mega16.h>
#include <delay.h>
unsigned char key;
unsigned char i;
void main(void)
    DDRD = 0xFF;
    PORTD = i;
    DDRC = 0x00;
    PORTC = 0xFF;
    while(1)
        if(!PINC.0)
                if(key!=p_state)
                        if(i==10)
                                i=0;
                                PORTD=i;
                        else
                      delay_ms(1000);
                       i++;
                       delay_ms(1000);
                        PORTD=i;
                        p_state=key;
        else
            p_state=0xFF;
    if(!PINC.1)
                if(key!=p_state)
                        if(i==0)
                                i=10;
                                PORTD=i;
                        else
                      delay_ms(1000);
                          i--;
                      delay_ms(1000);
                        PORTD = i;
                        p_state=key;
        else
            p_state=0xFF;
I use 7448 for my 7 segment and in this case it doesn't need to write
regard
pesarirouni
