Help finding USB controller/"thing" that can be programmed with C# for electric bike?
srb31513
Newbie level 1
Hello all,
First of all my appologies if this is off topic, but I don't know enough about electronics to even start looking in the right place...
I'm hoping the experts here can point me in the right direction, and solve this puzzle:
Essentially I need to interface an electic bike with a C# software running on a netbook via USB to do few rudimentary tasks. I'm not sure what this
USB controller is or if it even exists, but here is what this controller \ "thing" needs to do:
1. Pass some kind of input to software that approximately represents speed of wheel turning (accuracy / MPH not imporant...relative is fine)..I was
thinking about using a cheap bicycle dynamo that lights a 6 volt bulb or something similar..that I can wire to the controller "thing" that will feed
info back to software.
2. Outputs voltage regulation...so that I can limit output that goes to bicycle wheel..for example if I want to stop all current to wheel via
software. I'm not concerned about power details here..i will find a way to modulate / contorl power, but just need something that will alow me to do
it from software.
3. Software should light 6 different leds. For example if i click button on netbook I need a led to light...simple.
4. Softoware should respond to 5 buttons mounted on the bicycle frame...if i press button software get's an event and shows message on screen.
The key here is for software to handle all the events/inputs/outputs for speed, buttons, leds, and voltage regulator....etc i just dont know what the
USB "thing" is that has drivers and that I can program against and use to inteface with the electonics.
Can someone suggest what usb controller / "thing" would be appropriate for this setup? Or an adaptor or two that I can use to accomplish the same?
Again, my applogies for pre-newb questions...any help would be much appreciated. Thank you in advance for any and all help...
-Stan
Re: Help finding USB controller/"thing" that can be programmed with C# for electric b
See thise projects with PIC18F4550 and PIC18F2550. Both uC have integrated USB support. You have source codes for both PC software and uC firmware, and you can make and adjust this to your needs. You can use digital potentiometers, temp sensors, switches,....
Do you trying to impress some girl with this led show ? Maybe better if your bike have computer, make some real byke diagnostics. :)
:wink:
  • !!! USB 6 ADC, 16 Digital IO PIC18F4550.rar
  • !!! USB Data acquisition with PIC18F4550.rar
  • !!! USB HID I-O PIC18F2550.RAR
