I need to know if there is a compatible n-ch mosfet for these specifications. 863-NTP45N06LG is the mouser electronics pt number. 2x On Semi 60V 45A TO-220 N-Channel FET is what I need to repair the inverter board for an lcd backlight, but it is as if this particular FET has been discontinued because I cannot find it anywhere and I do not know how to find a comparable part. Anything helps guys and thank you in advance for your patience because transistors just aren't my specialty. Here's a direct link to the part I need.
