I have designed a multilayer stacked antenna comprising of dual polarized ports. Next step in my design is to make an array of 8x8 elements. For this array I am thinking of using Wilkinson power divider as a feed network, but unfortunately the feed network layout is not easy to come by.
Can anyone suggest any good paper to start working on or some other feed network options for the 8x8 dual polarized design.
I think generally a WPD for antenna feeding networks is overkill. You are essentially guaranteed the antenna port impedances are constant (unless you for some reason have unreasonably sized patches for a very low operating frequency); so isolation isn't really needed.
Standard T-junctions work well in practice. There are many such layouts in the literature.
@PlanarMetamaterials
Thank you for ur suggestion, Can you recommend some papers that present the 8x8 layout either with WPD or T-junctions.
My center freq is at 28 GHz and I am using micro strip aperture coupled technique.
Googling "T-junction aperture patch array" yields some good results.
Check out "Wideband Aperture Coupled Patch Array Antennas — High Gain, Low Side Lobe Design", Dhruva Poduval and Mohammod Ali, Progress In Electromagnetics Research, Vol. 160, 71–87, 2017
I read there paper availble on PIERS, good work by team.
But Im mostly interested in dual polarized aperture coupled patch array feed comprising of 8x8 elements or even 4x4 to get an idea...
