Nov 1, 2007 #1 S somachakraborty Newbie level 1 Joined Nov 1, 2007 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,289 Can u give me matlab codes for DSP?
Nov 1, 2007 #2 P pouchito Full Member level 2 Joined May 29, 2006 Messages 126 Helped 22 Reputation 44 Reaction score 9 Trophy points 1,298 Activity points 1,835 Specify what you want in the meantime check these if they are good **broken link removed** **broken link removed** **broken link removed** **broken link removed** check also the matlab site: **broken link removed**
Nov 2, 2007 #3 C cydi Full Member level 3 Joined Dec 12, 2006 Messages 162 Helped 14 Reputation 28 Reaction score 3 Trophy points 1,298 Activity points 2,004 Which is the DSP u r using? And wat is the algorithm?
Nov 2, 2007 #4 D dspman Member level 2 Joined Mar 14, 2004 Messages 42 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,288 Location ... Activity points 336 Hi somachakraborty It is not clear what you really want? DSP stands for Digital Signal Processor or DSP stands for Digital Signal Processing? You should clearly specify your need dspman
Nov 10, 2007 #5 C chickoos Junior Member level 2 Joined Sep 18, 2006 Messages 23 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,412 hi, u will get lot of example codes in the MathWorks website
Nov 14, 2007 #6 P proper Newbie level 4 Joined Oct 7, 2007 Messages 5 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location INDIA Activity points 1,303 Hey it is not clear what you want.. DSP + MATLAB releted what ?? any application ?? Some example avilable on MATH WORK & there is book avilable for DSP with MATLAB. use this book & enjoy Good Luck
