ahgu
Full Member level 3
- Joined
- Jun 19, 2001
- Messages
- 172
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 1,552
I need to read data from several camera and dump them into either high speed USB or Giga-E.
Total Camera bandwidth 140Mb/s
Cameras--FPGA---RAM(at least 16Mb)
MCU with USB+GIGAE.
One way is to use FPGA for everything including USB and GIGAE, but I have to write too much verilog code.
I want to use the MCU that already has USB/GIGE feature, so FPGA put the data into RAM and MCU send it out through USB/GIGE. The problem is how does the MCU interface with the RAM? What is the optimal way?
Seems it must go through FPGA so the read/write does not interfere. MCU has 16bit DDR1,2 interface logic. The RAM does not have dual interface like FIFO. right?
Thank you
MCU with USB+GIGAE.
Thank you
