Help - Design a Network Analyzer
johnseven
Junior Member level 3
California
RF people,
I am trying to design a Network Analyzer.
Questions :
What detectors?
Analog Devices log amps ?
What signal source?
Use DDS (direct digital synthesis) ?
Use oscilloscope for display?
or computer display?
Or provision for both?
Software ?
Thank you for ANY suggestions
johnseven
I remember reading the article about the Hagtronics in QEX. It is a very clever setup and I think it is the way you should go.
look at circuit caller 150 there is a full design up to 1 gh
look at circuit caller 150 there is a full design up to 1 ghz
bobi
circuit caller ?
Bobcat1, can you explain me what is circuit caller ?
Thanks
Mandi
hi
i hope my experience in designing a spectrum analayzer can help u
1.For detector u can use a digital filter with dsp and measuring its power after filter
2.For log amp u can use ad8307 that have 80dB dynamic range and DC-500MHz Bandwidth
3.For signal source u can use a DDS or Hybrid PLL-DDS frequency synthesyzer
4.And finally if u use computer for display u can interface with ur DSP from computer easily.
Bests
Technical help from members
Bobcat1, Gakusei and Circuit_Seller.
I'm reading and following your many links/suggestions.
Very useful, indeed.
The first quick'n dirty experiment "to get a feel" for the problems, using
Analog Devices's AD8302 works. Good chip with mag and phase detectors,
but with only 60 dB range.
I'll proceed.
Thanks again,
J7
Hi johnseven
I read AD8302 datasheet, but i did not find anythings about its performance below 100MHz.
Do you have expriences in working with it below 100MHz? is it still have good performance?
Regards
Circuit_seller said:
Hi johnseven
Regards
Soryy for the delay. I was traveling ...
Yes. It works well in those frequencies too. I tried it as low as 5 MHz and it performed as well as at 100MHz.
there is design at cypress using the PSOC chip .. it was an awarded design .
i got all the parts and never put it together .But is a nice design
