Since you are using edge port, there must be two metallic faces (positive and negative) attached to the edge.
From your figure, its clearly seen that only your edge(feedline) is of metallic in nature.
Hello Soundav! do you mean that I have to define another metallic face, if so where should it be placed in your opinion?!
Note: I am using a student version 14.0.
