El_Paco
Member level 1
Hello,
some advice is needed
Old system (see picture):
1. a heater is connected to power (24 V) by 2 relays as shown in the circuit.
2. later the heater is disconnected for short times from power
3. ac voltage of 5 V is applied
4. the current of the voltage is measured for detection
5. heater is again connected to power
new system should be realised with semiconductors because of the space limitation.
possible solutions:I
1. usage of transistor as switching elements --> hint : power loss --> Uce = 0,7V / I = 24V/4R=6A --> P(transistor) = 4,2W
2. usage of Mosfet instead of relays --> hint : body diode between Drain - Source -> conduction in reverse polarity....
someone has some advise?
best regards,
Frank
best regards,
Frank
