help....... cannot start up calibre on vituoso calibre menu
foter
Newbie level 3
I've installed redhat as3, IC 5.1.41 and MG Calibre 2004 all seems to work fine... however, when i try "Run DRC" from the custom Virtuoso Layout "Calibre" menu, it doesnt start up. Running Calibre from command line seems fine and it isn't a license error. Have tried the same with IC 5.0.33 and this has the same issue. Is it something to do with redhat as3??? Would appreciate any help !!!!
hi, please add the followiing line in you .cdsinit
setSkillPath("$MGC_HOME/shared/pkgs/icv/tools/queryskl")
load("/tools/calibre/ixl_cal_2003.4_9/shared/pkgs/icv/tools/queryskl/calibre.skl")
Re: help....... cannot start up calibre on vituoso calibre m
I think you can see the "calibre" menu in the Virtuoso. You already add .cdsinit file.
I guess you login RH as 3 in other language, not english.
Try to login RH AS3 in English and click the "run drc" again.
I hope it can help you.
