Help about SIM900 gsm module using with atmaga8
NAYYERBABA
Newbie level 5
Pakistan
Hi e
I'm new to gsm communication system please help me i'm using sim900 gsm module with atmega8 & set the baud rate 9600 kbps but modem not respond i think i wrong with baud rate.
any know about that please help me
thanks
Hi e
thanks
Please check and verify your modem is alright. Connect to a PC and check the commands on a hyperterminal software. Then if the modem is responding go ahead and interface the controller. make sure you have given the right power supply between 3.6 to 4.5V
Did you read the data sheet of sim900? The modem has an autobaud rate detection. All you have to do is to write AAT when you ist time boot up the device. When you send "A" the modem adjusts its self to Autobaud rate and give response to AT command.
