kkdelabaca
Full Member level 2
hello
Somebody can help me to translate this schematic to one VHDL code?
I do not understand how connect the internal nodes.
THANKS !!
/******************** CODE FOR MULTIPLEXOR *********************/
library ieee;
use ieee.std_logic_1164.all;
entity Mux is
port( I3: in std_logic_vector(2 downto 0);
I2: in std_logic_vector(2 downto 0);
I1: in std_logic_vector(2 downto 0);
I0: in std_logic_vector(2 downto 0);
S: in std_logic_vector(1 downto 0);
O: out std_logic_vector(2 downto 0)
end Mux;
architecture behv1 of Mux is
begin
process(I3,I2,I1,I0,S)
begin
-- use case statement
case S is
when "00" => O <= I0;
when "01" => O <= I1;
when "10" => O <= I2;
when "11" => O <= I3;
when others => O <= "ZZZ";
end case;
end process;
end behv1;
/***********************CODE FOR COUNTER **********************/
library ieee ;
use ieee.std_logic_unsigned.all;
entity counter is
generic(n: natural :=2);
port( clock: in std_logic;
clear: in std_logic;
count: in std_logic;
Q: out std_logic_vector(n-1 downto 0)
end counter;
architecture behv of counter is
signal Pre_Q: std_logic_vector(n-1 downto 0);
begin
-- behavior describe the counter
process(clock, count, clear)
begin
if clear = '1' then
Pre_Q <= Pre_Q - Pre_Q;
elsif (clock='1' and clock'event) then
if count = '1' then
Pre_Q <= Pre_Q + 1;
end if;
end if;
end process;
-- concurrent assignment statement
Q <= Pre_Q;
end behv;
THANKS !!
library ieee;
entity Mux is
end Mux;
begin
begin
case S is
end case;
end process;
end behv1;
library ieee ;
entity counter is
end counter;
begin
begin
if clear = '1' then
if count = '1' then
Pre_Q <= Pre_Q + 1;
end if;
end if;
end process;
Q <= Pre_Q;
end behv;
