janova
Newbie level 1
formality problem
I'm using Formality to verify the equivalence between RTL and Netlist.
The top module failed because of some failing points in a sub-module ABC.
However, the sub-module ABC can be successfully verified when run singly.
In the top level netlist, the netlist of ABC just be read in and linked, and have set set_dont_touch property in DesignCompiler.
Have anyone experienced this? Any suggestion about the debugging method?
Tks a lot !
Tks a lot !
