Hi everyone,
Thank for your time,
I'm a french young engineer, and I'm stuck on a problem.
I'm trying to understand a PCB my company is using for Ozone generation - IE High Voltage board -
Here is a diagram I've made from this PCB
IC is a SG3525AN
both IGBTs are FGA25120ANTD
View attachment HV.pdf
The HV transformer is the TX2
So, as far as I understand, the IC is driving both IGBTs through outA and outB that induce current into the tranformer which applies current to the gate and "ON" both IGBTs.
There are 3 small variable resistors on the board, one drives IC frequency, one drives feedback loop (top right)(?), and last one duty cycle (?)
The last variable resistor (top left) is the potentiometer the customer can use to adjust the amount of ozone
I'd like to understand what's the second IGBT used for ? The one on the right. Because as TX2 is directly powered by the first IGBT, if this one is "ON" the second one should be useless ?
And what is the influence of the POT3 ? Does it drives IC duty cycle ?
If someone can explain to me, it'd be awesome !
Thanks;
Martin
