[AVR] Help [16x2 LCD interfacing with atmega16]
pavan.chvs95
Newbie level 2
Newbie level 2
Hi guys,
I am new to this forum as well as to AVRs.Ive recently tried to interface Atmega16 with an LCD display(16x2).I am using PORTD as data port and PORTB for control signals.Clk frequency is selected as 4Mhz(internal).
The code is as follows:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
#define F_CPU 4000000
#include <avr/io.h>
#include <util/delay.h>
#define MrLCDsCrib PORTD
#define DataDir_MrLCDsCrib DDRD
#define MrLCDsControl PORTB
#define DataDir_MrLCDsControl DDRB
#define LightSwitch 2
#define ReadWrite 1
#define BiPolarMood 0
void Check_IF_MrLCD_isBusy(void);
void Peek_A_Boo(void);
void Send_A_Command(unsigned char command);
void Send_A_Character(unsigned char character);
void Send_A_String(char *StringOfCharacters);
int main(void)
    DataDir_MrLCDsControl |= 1<<LightSwitch | 1<<ReadWrite | 1<<BiPolarMood;
    _delay_ms(50);
    Send_A_Command(0x01); //Clear Screen 0x01 = 00000001
    _delay_ms(50);
    Send_A_Command(0x38);
    _delay_us(50);
    Send_A_Command(0b00001110);
    _delay_us(50);
    Send_A_String("Newbie");
    while(1)
void Check_IF_MrLCD_isBusy()
    DataDir_MrLCDsCrib = 0;
    MrLCDsControl |= 1<<ReadWrite;
    MrLCDsControl &= ~1<<BiPolarMood;
    while (MrLCDsCrib >= 0x80)
        Peek_A_Boo();
    DataDir_MrLCDsCrib = 0xFF; //0xFF means 0b11111111
void Peek_A_Boo()
    MrLCDsControl |= 1<<LightSwitch;
    asm volatile ("nop");
    MrLCDsControl &= ~1<<LightSwitch;
    Check_IF_MrLCD_isBusy();
    MrLCDsCrib = command;
    MrLCDsControl &= ~ ((1<<ReadWrite)|(1<<BiPolarMood));
    Peek_A_Boo();
    MrLCDsCrib = 0;
    MrLCDsCrib = character;
    MrLCDsControl &= ~ (1<<ReadWrite);
    MrLCDsControl |= 1<<BiPolarMood;
    Peek_A_Boo();
    MrLCDsCrib = 0;
    while(*StringOfCharacters > 0)
        Send_A_Character(*StringOfCharacters++);
Now,the problem is that the output is discontinuous.(For example if i send "Newbie",output is like "N w b e").
Can any one please help me with this problem?:roll:
Ive tried putting 1ms delay as you said,but no change.
Ive also loaded your program after changing the port configuration in program.But,the output is blank.:-?
Check if the routine Check_IF_MrLCD_isBusy() is working properly, taking special attention to logic levels of control pins.
