Hello ,guys . Anybody knows how to confirm the impedance of the microstrip ?
For example ,I have simulated the width of the microstrip for 50 homs .But I don't
know whether the impedance of pcb tracks from pcb manufactory is correct ? How to confirm ? Best regards !
Yes, correct, but usually it may be experimented that measured Zo differ a lot from the simulated one, also in the case that all is correct and well manufactured.
This is due to end effects and µstrip launchers.
To reduce this effect and focalize the attention to the line only, use a Time Domain VNA. Both Agilent and Anritsu have very efficent and useful TD algoritms.
Appreciated !Do you think that is accurate measure the character impedance Z0 by the VNA ?
Could you please tell me the detail stap for measurement ? Best regards !
By definition the main designation of VNA is to measure impedances.
Time Domain Reflectometry (TDR) is more accurate than frequency domain Vector Network Analysis (VNA), because do not depend by frequency.
But for commercial applications frequency domain is more than ok.
Check this document: **broken link removed**
u can also do it with network ana. just measure inserstion loss and return loss on smith chart. return loss will tell u the impedance of the line. if the rerunloss is as close as possible to center of the smith chart its a 50ohm line
