am trying to build an inverter of 3.5kva,so far it is working but not up satisfaction because my transformer first of all was heating up seriously when charging then i replaced it with a higher rating next the mosfets started heating also beyond normal, now i am stock i need help don't know what to do next,.am using irf150[2x6] pieces and sg3524 for the oscillation...
24vdc
50hz
modified sine wave
about 2000w load
220230vac
about 20amps
i mean 220vac as both input for charging and output from inverter
output with a curent of about 20amps
2x12v battery of 200ah] to give 24v 200ah
