go ahead
Junior Member level 1
- Joined
- Aug 30, 2012
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,421
hi
i working on some project and facing problem with all regulator(lm317, lm2576 5v, 7805)
i am using AT89s52 + HC05(Bluetooth module) + solenoid valve
my task is simple on/off solenoid valve via bluetooth through android app.
micro-controller works upon 5v and solenoid valve operates on 24v. problem is, the regulator :-x
i have used lm317 , lm2576 5v ,7805 with proper heat sink on 24v dc adopter. each and every regulator as mentioned, is heat up within short time period. :???:
i know about power drown will be heat up the regulator but when i only connect Bluetooth with lm2576 5v, its still heating up.
needed help to sort out this .
thanks in advance
thanks in advance
