jit_singh_tara
Full Member level 6
- Joined
- Dec 22, 2006
- Messages
- 325
- Helped
- 9
- Reputation
- 18
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Delhi , India
- Activity points
- 4,295
Dear Friends ,
I need to drive 3000 watt heater for maintaining a temperature of 190 deg. I want to know which method would be best for reaching the desired temperature without overshoot .
1. Running the heater constant ON for certain temp like 100 deg , then start switching the heater on /off , decreasing the on time as the temp approaches set temp.
I tried the above method but got an overshoot of 10 deg and undershoot of 15 deg in first run ,
What is the best method to do such thing .
Can we reach the desired temperature like this in first run , though it can take some more time by lowering the constant on point from 100 to say 80 or so and then switch on /off.
Please suggest the best method to do so .
One more thing i would like to know how would be the response of heater ,ssr with pwm of a fixed frequency . Will ssr be able to deliver the current at high speed say 1/50 of a sec .
Will HEATER(3000 W) , SSR , PWM be a good driving technique so as to have minimum overshoot and undershoot.
Please share some ideas regarding PID algorithm and auto tuning or manual tuning and its advantages over other driving techniques ?
